Likely supply failure or shorted pannel driver. u should be able to unplug the pannel boards from the power supply. if the buzzing stops than its the pannel boards otherwise its supply.
I have this tv aswell, and yes I will confirm that it does buzz quite alot, but all plasma tvs do, it is to do with how it renders images, the buzzing can be made worse by it being close to a wall and it reflecting back. I found that my tv stand some how amplified the buzzing when i got mine. I dont think its something you can escape.
Mine i notice also when scrolling around menus seems to have lines that follow your selection....not to pleased about that
Samsung states - A buzzing sound from your plasma TV is normal. It is caused by the electrical charges used to create the images on the screen. The buzzing, however, should not be so loud that you can hear it when the volume on the TV is set at normal levels.It is also important to determine the type of buzzing sound. A sound like a ground hum is completely normal. This buzzing can originate near the power cord connection or from the SMPS board position on the upper back of the TV. The buzz will be more audible as contrast increases on the screen, most notably when displaying an all white screen. If the buzzing sound is loud, you may have the Contrast set too high. Lower the contrast to reduce or eliminate the buzzing.You may also have loud buzzing if the rear of your Plasma TV is too close to a wall or other hard surface. Try moving your TV away from the wall until the buzzing is minimized. [1] If the buzzing is at a higher frequency and resembles a crackling sound (like the sound of Velcro being pulled apart), and originates from the upper middle back of the TV, you likely have a failing SMPS board. Place a support call with Samsung to have the SMPS board replaced.FP-T5084 Have a known buzzing problem with a very simple fix.If the buzzing is coming from the left or right sides of the rear and the volume can be changed by pressing lightly on those locations, you are probably hearing the vibration of the grounding springs on the back panel. Call Samsung (or whoever) and have a technician confirm the problem. The easiest fix is to insulate the offending spring by applying some felt tape.
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
Vizio makes an ok LCD, but if you notice they no longer make plasma. they stopped last year. Anyways. the buzzing sound is semi serious, it sounds as though you have a capacitor leaking. It is best to get it fixed before it goes out all the way, with it buzzing it will be easier to identify. Best of luck
