20 Most Recent
Vizio VW37L 37 in. LCD TV Questions & Answers
How do i connect internet to a vizio vw37L tv
Yes, if after you checked all the connections source then your main board is defective. The Wifi/B in the tv could be on the main board or close to the main board but have a tech come out and replace it.
Need new remote for vizio lcd flat screen t.v.
You can get Universal Vizio remotes from Walmart for around $10 or you can get replacements on Ebay. I have a couple OEM Vizio remotes I will be listing on my website as well for $10 @ http://back2lifeelectronics.com/Inventory.html
I have a vizio vw37L and after about a min or so
Does the screen go black or does the screen turn off? To determine this, cup your hands place them against the screen with your face in your hands. This effectively blocks all other light out, if the screen appears to be lit even though it is black, the screen is still on.
If the screen in on but black,
1. Check the cables that are attached. If there are separate cables for the video and audio, make sure the video is properly inserted.
2. There is an internal problem with wiring. Check your warranty and try and return it or get it repaired.
If the screen is off,
1. The lamp is burned out inside the tv. This is usually a free fix if the tv is under 2 years old. Contact the establishment where you purchased it or the manufacturer for details.
37in vizio no pic no sound
i joined up to answer this question took me awhile to find the post...main board. I had the same tv do the same thing swapped out the main board still works today repaired it year and half ago...
is the screen lite up white'ish or blue'ish....
I have a mfg date 2007 Vizio VW37L HDTV10A turned
This can happen. are the lights on? if not, it most likely id the power source inside the tv itself. make sure your wall outlets are working properly as well, but if they are, then you want to get you tv fixed. this can be a relatively low cost repair, but shop around
37 inch visio LCD TV
Sounds like its going to be the power board that is culprit if your not getting any led's to light up when you turn on the TV.
http://cgi.ebay.com/VIZIO-PART-VW37L-HDTV20A-POWER-SUPPLY-0500-0507-0440-_W0QQitemZ230385884230QQcmdZViewItemQQimsxZ20091008?IMSfp=TL091008154001r16635
Thats what the power board looks like.
Vizio VW37L
720p & 1080P are what you want, the vizio has a higher repair rate than most, check out the toshiba or the samsung
Vizio V705-H1 started having display issues. The background seems okay but words have tracers.
Check Connections:
Ensure that all cables connecting your TV to external devices (such as your cable box or gaming console) are securely plugged in. Loose connections can cause display anomalies.
Test Different Devices or Apps:
Try using other devices or apps with your TV to see if the issue persists. If the TV's menu looks fine but a specific device is causing trouble, that device might be the culprit.
Adjust Picture Settings:
Navigate to the picture settings by pressing the 'Menu' button on your remote.
Experiment with different picture modes. Sometimes a minor adjustment can resolve display problems.
Soft Power Cycle:
Unplug your TV from the power source.
Press and hold the power button on the TV for about 3-5 seconds (this helps drain any residual power).
Plug the TV back in and turn it on. Some TVs also have a 'Soft Power Cycle' option in their settings menu, so check there too.
As you have tried a reset, that takes us to the options of contacting Vizio support and/or your warranty.
Vizio all in one computer VIZIO CA-27 voltage and part number for subwoofer/power supply replacement
The power supply/subwoofer for the VIZIO CA-27 series all-in-one PCs is identified by the part number 715G6960-P02-001-002S or ADTVE1825AC71. The power supply connects to the motherboard via a proprietary dual jack Audio/Power cable. I couldn't find specific voltage details for the subwoofer/power supply in the available resources. For precise information, I recommend checking the user manual or contacting VIZIO customer support directly.
