SOURCE: Laars lite 2 Spark egnighter will not spark
turn power off first. I would disconnect igniter wire which will be a thick orange wire that comes off of ignition module if it is spark. once you have that the end will look like a spark plug wire take shield away from metal then hold orange wire in hand close but not touching metal turn power on and it will take a couple of minutes before it should start sparking. If you don't see a spark then it is most likely the ignition module. There should be a red light on ignition module that will blink to tell you what the failure is if is is a newer on. When you turn power on to laars light 2 the inducer motor should come on then a pressure switch should send 24volt to gas valve for pilot to lite.Can you smell gas at all when laars should be igniting. If you have any questions fell free to email me back
SOURCE: Laars Lite 2 Pilot will not light
If you have not found the problem yeat, it IS the thermocoupling( or pilot generator(same thing))
You may test by placing a multimeter on the red and white leads coming to the gas valve. you do not need to disconnect the leads first but you can
SOURCE: laars lite 2 pool heater burner not lite
ive got the same problem and am fitting a new thermal generator i will let you know if it works
SOURCE: How do I access the Pilot Generator on a Laars Lite 2 Heater
No cleaning. Ilot has to keep thermocoupler hot or no gas.
SOURCE: switching from natural gas to lp gas
Get in contact with the appliance manfacter, ask them for a conversion kit and if it can be done they will send you out all you need. Obviously there will be a charge.
