Apogee Ensemble Sound Card Logo
Posted on Dec 02, 2008
NO SOUND - APOGEE & SPEAKERS HOOKED UP
I have the new macbook pro. I connected to apogee ensemble, and have adam a7 monitors attached via analog ouputs to apogee. I can't get sound from anything, and I installed drivers for leapord. When I turn apogee on, ouput lights don't turn on with it, only input lights do. PLEASE PLEASE HELP ME!!
Radix Veghel
Level 1:
  • Contributor 4 Answers
  • Posted on Jan 04, 2009
Radix Veghel
Contributor
Level 1:
Answers
Questions
0
Helped
797
Points
Be sure that you download the latest software updates from the web.
Than check with the identifier button in Meastro, that the commands go to the right machine.
Verify the matrix, mixer and hardware settings in Meastro.
Even with quicktime you should see vu meters in Meastro light up now.
Check that the analog connectors are firmly pushed.
Almost my choise Adam A7, but finally went for passive Quad 12L on Rotel amp.
It was difficult to compare speakers from different shops. (music shop vs. hifi shop).
I use iMac 24 inch with Logic express 8, and connect Neumann microphones to the Apogee.
Baptist Clauwens,
Veghel, Netherlands
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 03, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
468
Points
Possibly obvious... but on the maestro control / settings  meter display /output /input
  • Anonymous Jan 03, 2009
    also...my 1st apogee the lights for mic1 and both headphone did not work.
How do I find out what my current usage is ?
Use the meter to read for an hour and then for a day.
Digital Energy Monitor - Electrical, Series 1000 / 2000 ...
Siemens https://sid.siemens.com > ...
Digital Energy Monitor - Electrical, Series 1000 / 2000 Technical Specification Sheet - Data Sheet for Product. 44908_en.pdf. Product Family: APOGEE; Product ...
538-986_Digital Energy Monitor - Electrical, Series 1000 / 2000 Installation Instructions.
Remote control battery
check side for thin/blade slid on the side of the unit that where the battery hid may be its lithium type.
How to install audio driver to my PC?
just download it from the apogee site after registration on the site and follow the instructions
be aware , for PC only until xp you can have drivers. Vista doesn't work, and windows 7 some people have good experience , others don't.
1helpful
I have an Apogee 40 (Cynosure). Don't know where to add water
you have to have the funnel device that locks into the water chamber. you hold it upright until the correct amount of water is drained into the water chamber. I have one if you would like to purchase it. Call me 314-862-1000 Thank you,, Julia
A buzzing sound
The cables always a usual suspect, but if you are using a tube mic, wich have their own power supply, you don't use phantom power and it can damage the mics power supply, so take phantom power off that mic and if that doesn't cure the buzz then I would change the cable next.
Wiring Diagram
Browse this site Chaintech.com and Shopzilla.com,all types of motherboards from chaintech is there..
Goodluck!! =)
Buzzing sound coming from monitor speakers
Check your leads, chances are it's a faulty/dodgy lead coming from your macbook to the system.
Top Apogee Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Apogee Computer and Internet Expert? Answer questions, earn points and help others
