Dear all, As per your answer I had already reset the CMOS by Jumper setting & also change the CMOS Battery 2 - 3 times New one but the Problem is not resolved I had also tried to load optimize Default settings but it's also not working. When a Computer is Boot message is coming that CMOS Settings Wrong CMOS Date / Time not set. Please help me ......... Be Helpful................ Thanks in Advance................
I'm sorry to have to say this but your CMOS battery connection is bad. There is basically nothing you can do other than replace the whole motherboard if it is too much of a problem.
One of my many computers is like this as well. I'm lucky in that as long as I leave that computer plugged in (it doesn't need to be turned on just plugged in), the CMOS won't reset its self. If you aren't that lucky then I would seek out a replacement motherboard.
SOURCE: faulty time settings p5rd1 vm
Hello!
That's the 2nd time i hear that kind of problem. Your mboard battery is new, and you did not press "f1" at first start.
so i guess , the cmos time is not change, try go to the bios setup and load "bios setup default." after that change the time setting on the bios. please find time setting and set it with a current ime in your area. after setting press 'F10" to save and exit the setting, the system will restart.
may this help!
best regards, melnavz
