RCA D52W19 52" Rear Projection Television Logo
Posted on Dec 02, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
TV won't turn on after cable outage
I have an RCA 50 something inch projection set that is about 10 yrs old. I had a cable outage this morning and now that the cable is back on the cable box says STANDBY. I called the cable company who tells me it's the TV that is on standby. I disconnected the cable box and still the TV does not turn on. I've tried unplugging the set for a few minutes but still no luck. I changed the batteries in the remote and that did not help. I tried to turn on the set on the TV itself, still nothing. The cable box is still saying STANDBY. All other TV and cable boxes in the house are working. Is my TV dead? I cannot find the model number of my set on the TV or in the maual so I am assuming it is the same model I picked from your drop down box below.
  • Anonymous Feb 01, 2009
    okay so i unplug the T.V FOR HOW MANY MINUTES
  • Anonymous May 11, 2010
    What is the year/ model number and chassis number?
Anonymous
Level 3:
  • RCA Master 5,138 Answers
  • Posted on Dec 18, 2008
Anonymous
RCA Master
Level 3:
Answers
5138
Questions
5
Helped
1004564
Points
13534
No your set would not be like the HD52W19 model ,your model number is on back of tv year,chassis & Model # being 10 yrs old ptk195 model------- older Rca ptk169 these sets are 16yrs old.My guess without hands on chassis Bad Flyback Transfomer.
50 or 52 inch RCA HDTV about 10 yrs old the power light blinks 9 times then 5 times then 9 times and won't go off unless unplugged, won't turn back on
i have seen this before and sorryy to say if unplugging for 5 or more min and that dose not fix it may need to be replaced not many people fix them these days but not impossable
I have an RCA 50 something inch projection set that is about 10 yrs old. I had a cable outage this morning and now that the cable is back on the cable box says STANDBY. I called the cable company who tells...
I found out the model number is P52820BL and after researching on the internet further I found this set has a problem with power outages. I found a site that told another person with the same problem that it would take about $350 to fix - if it could be fixed - and there is no guarantee it would work for long after. Therefore, we decided not to bother fixing it. We are getting a new one.
52 inch RCA TV Model P52755BA about 12 yrs old
probably you have glycol leaking on the anode lead, in one off the pic tube, check for wets spots, or pay attention on the chassi where the hv leads are located, be careful
TV WOULDN'T TURN ON
it could be a blown fuse check those first if its not that something might have been fried from the power outages
RCA 50in Rear projection TV Turns on and off every 30 seconds-New
if u have only had it a month it should be under warranty get them to repair it
3helpful
3answers
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
TV won't turn on with remote
Unplug your set from the wall and wait a few minutes. This fixed the same issue on my 50V715
yes it could ba the cable itself even, but i suspect more the tuner circuit or tuner itself may have bad solder connections. Here is another test for you to try, plug another dvd or vcr, or xbox etc. into the back, using one odf the inputs. See if this works like the built in dvd. if so it will be more likely bad connections in the tuner or surrounding circuit. good luck.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
