I have installed 2 Sarkle 9800gt's in Sli and the second card gives me the code 12 error that it cannot find enough free resources. I have used the SLI bridge from my previous sli installation(6600gt's) as i did not recieve a new bridge with my 9800gt's.
There is also a small plug on each card right next to the sli bridge, must this be plugged in?????
Please help
SOURCE: "This device cannot find enough free resources that it can use. (Code 12)"
Two devices have been assigned the same I/O ports, the same interrupt, or the same Direct Memory Access channel (either by the BIOS, the operating system, or a combination of the two).
You can use Device Manager to determine where the conflict is and disable the conflicting device. On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
SOURCE: error code -12
go to control panel>> system>>hardware>> device manager.
double click on the netgear, go to resources tab, if there is conflict (it should). click on "change setting" select the memory range and the IRQ untill you see "no Conflicts" in the lower box.
close and exit. restart the machine.
