20 Most Recent ASUS A8N-SLI Deluxe Motherboard Questions & Answers
No son gt 630 on tv with hdmi
go to the sound icon on the taskbar with right click then open playback devices and again with a right click on the device you need the audio to come out set as default. You can even test if the output is right.
8/18/2014 11:11:13 PM • ASUS A8N-SLI... • Answered on Aug 18, 2014
Beep codes failure
check ram out first then video card then cpu heatsink
5/19/2014 7:33:39 AM • ASUS A8N-SLI... • Answered on May 19, 2014
Asus p5ge-tvm/s motherboard drivers
This is a OEM mainboard not realy a Asus one the drivers you need can be found here: http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=4&PFid=4&Level=5&Conn=4&DownTypeID=3&GetDown=false&Downloads=true#RTL8110S-32/RTL8169S-32/RTL8110SB(L)/RTL8169SB(L) RTL8110SC(L)/RTL8169SC(L)>
5/11/2014 10:21:47 AM • ASUS A8N-SLI... • Answered on May 11, 2014
0answers
Boot up failure
Nead to set boot divice.
2/18/2014 8:37:48 AM • ASUS A8N-SLI... • Answered on Feb 18, 2014
Beep codes
change video card
11/11/2013 7:45:13 AM • ASUS A8N-SLI... • Answered on Nov 11, 2013
0answers
Nvenetfd inf
Be the first to answer 9/27/2013 4:16:39 AM • ASUS A8N-SLI... • Posted on Sep 27, 2013Be the first to answer
4answers
ASUS P5G-TVM/S
Hi. I have the same motherboard. In russian it`s called DERMO
You can find drivers for P5G-TVM/S:
http://ftp.maxdata.de/MAXDATA%20PCs/MAXDATA%20Desktop/Driver/Mainboards/ASUS%20Mainboards/ASUS%20P5G-TVM/
or
www.maxdata.de...
3/27/2013 3:53:42 PM • ASUS A8N-SLI... • Answered on Mar 27, 2013
Was on my PC it is a Alienware Area 51 older PC but has worked fine for what I need, anyway it was workin fine and I went to turn the tv and the motherboard said something failed, I removed the memory
Hello it sounds like the power supply is failing, or the graphic card.Did you get any fault code on the screen ???Blue screen of death ???Try also to look here:http://www.tomshardware.co.uk/forum/261145-13-perform-steps-posting-boot-video-problemsYou are welcome to post back a comment.Good luck
2/7/2013 9:15:13 PM • ASUS A8N-SLI... • Answered on Feb 07, 2013
Cpu faulty?
I bet on GPU (Graphic Processor Unit not CPU(Central Processor Unit) ) if you have a graphic card change it or if it's integrated graphics add a graphic card or change your motherboard
11/22/2012 2:43:03 PM • ASUS A8N-SLI... • Answered on Nov 22, 2012
Asus a8n sli deluxe motherboard diagram manual?
Download page.http://www.asus.com/Motherboards/AMD_Socket_939/A8NSLI_Deluxe/#downloadYou must choose an OS like XP. Required, but indifferent. Click on Manual and choose Global link.
10/15/2012 2:44:09 PM • ASUS A8N-SLI... • Answered on Oct 15, 2012
How do you tell if ram is bad
click start right click on computer you will see the ammount of ram installed and the ammount of usable ram
To test RAM check here - let it run 4+ hours or so. <-- best methodwww.memtest.orgif you are having problems with the ram the modules and or ram sockets might need to cleaned
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry. They will air dry in a matter of minutes
If reseating the memory did not resolve the issue try swapping the location of the memory.
If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
Check the memory module and memory slot contacts.
They are either copper tin or gold.
The colour will tell you which they are.
Mixing tin and gold can result in corrosion that prevents proper contact.
Look for any sign of physical damage to the memory module, memory slots or the motherboard.
Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard.hope this helps
9/19/2012 7:52:50 PM • ASUS A8N-SLI... • Answered on Sep 19, 2012
2answers
What are its BIOS Beep code details?
The codes are different for each motherboard. Find yours here:http://www.computerhope.com/beep.htm
8/22/2012 1:01:33 PM • ASUS A8N-SLI... • Answered on Aug 22, 2012
No sound from my Asus MB
have you disabled the built in sound system on your computer? If you don't your softwatre can have problems picking up the right card.
8/11/2012 1:31:34 PM • ASUS A8N-SLI... • Answered on Aug 11, 2012
It has unconventional BIOS Beep Codes. Any one has the correct codes?
Correct codes for what?
5/16/2012 5:26:18 PM • ASUS A8N-SLI... • Answered on May 16, 2012
5answers
Asus motherboard
Hi austenitic, there does not appear to be a Asus P5G-TVM/S board. Please look directly on the Asus board & you will find (In White lettering) the correct model number.
To look for the Asus board you're self click on the link below.
In the top right hand corner is a Search window. Type in you're model number & click the -----> (Arrow button).
Or post the correct Asus model.
If I can be of more service, just post back & let me know how thing go.
Mike
3/25/2012 7:08:15 PM • ASUS A8N-SLI... • Answered on Mar 25, 2012
0answers
Need manual for asus a8n sli motherboard
Hope this what you are looking for, I found it on the Asus Website, is on PDF format. HERE
1/24/2012 8:04:33 PM • ASUS A8N-SLI... • Answered on Jan 24, 2012
ASUS A8N-SLI Deluxe Motherboard Logo
122 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
cpu faulty
  • Computers & Internet
