THE MAKER IS LONG LONG DEFUNCT AND GONE DIED 2001. (READ THE WIKI) LIQUIDATED. AND BOOKS WERE ON PAPER.THEN SO GOOGLE OR EBAY THE BOOKS BUT GOOD LUCK ON THAT. NO PROBLEM TOLD ALL NEED PARTS. OR HOW TO DO A SERVICE STEP. OR WHAT>? POSTING A NOUN FRONT TIRES MEANS ZERO TO ME. THE FRONT AXLE NUT COMES OFF, DO THAT? AND IS PINNED. MUST BE DRIVEN OUT. THAT PIN I HAD ONE OF THESE BACK IN 1990 AND GAVE IT AWAY TO FRIENDS AS I MOVED. AND UPGRADED TO TROYBULT HORSE WOW. PAGE 14 SHOWS BZ PIN GOOGLE SHOWS THIS
Remove sediment bowl from carburetor, clean all junk from bowl, then clean vertical and horizontal orifices in bowl nut, carefully install bowl and make sure bowl gasket is in place.
Try running at half choke until the engine warms up. If this doesn't solve your problem, the carb need adjusted. Adjustments are at the side of carb. there is idle and high adjusters. Also some may have a separate air/fuel mixture.
If it only runs with the choke on it isn't getting enough fuel. You will probably have to disassemble the carb, and clean well. Engines and carbs vary, but the main fuel passage from either the tank or fuel bowl, just be clean. Sometimes just blowing out won't do. Might be worth buying a carb kit, and clean it throughly. Sears web site will have a great parts breakdown if you enter the model number. See link: www.searspartsdirect.com
THAT WOULD BE WATER IN THE GAS .. DRAIN IT ,
REPLACE IT WITH FRESH GAS WITH AIR FILTER OFF USE A FEW DROPS OF GAS TO PRIME IT AND USE YOUR HAND TO CHOKE IT IT WILL TAKE SOME TIME TO GET THE REST OF THE WATER OUT OF THE CARB .. SAY ABOUT 5 MINN. COVER YOUR TILLER .. .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
