Hi, I have a nokia 6170 mobile that appears to be locked on use with a headset. The only way I can answer or make calls is to hit the loudspeaker button. The only other option is to change it back to headset. The problem is I don't have a headset and have never used one, so I'm not sure why it thinks I'm using a headset. Can this be fixed.
Cheers
My problem is identical, i've tried factory default settings with out success.My problem is identical, i've tried factory default settings with out success.
AnonymousApr 08, 2008
Has anyone figured out how to fix this!?Has anyone figured out how to fix this!?
AnonymousApr 01, 2009
I can only hear the phone ringing on the headset or on speakerphone. Have tried suggestions but to no availI can only hear the phone ringing on the headset or on speakerphone. Have tried suggestions but to no avail
You can't post conmments that contain an email address.
Note : Please try unlocking your Nokia 6020 mobile phone only once using the steps given below with the Nokia 6020 unlock code you get from our unlocking tool. If it does not work, do not try again as it may get your Nokia 6020 permanently locked. Do not enter any wrong unlock codes on your Nokia 6020 mobile phone. If you enter over a certain amount of wrong unlock codes on your mobile phone, your Nokia 6020 phone may get permanently locked and sometimes become unusable.
1 - Switch on your Nokia 6020 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6020.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6020 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6020 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6020
U must RESET the Headset. Switch OFF the Headset. HOLD the answer/end key + power key (for about 5 second). Red + Green indicators lights start to alternate. Then Ur Headset is RESET.
There is some problem with your phone mic only.please use your headset to check it.Connect your headset and answer phone with your headset.If the person don other side hear you then the problem is with the mic only.Please take the mobile to NOKIA CARE centre and they will repair the mic.
The yellow colour swiggly object which comes next to the battery bar is nothing unusual.It shows that your call is been connected with the person on other side.This symbol will not appear when the other person's phone is ringing,When the person picks up the phone this yellow colour symbol will apear.]
what you will do,you will press*#7780# then it will want your password,then you will put your password and wait few minuts,if your ph take restart automaticaly, then ok, other wise you will restart your ph manualy
switch off your mobile first. Hold the following 3 keys simultaneously. Call button(green button), * and 3(number button) With there 3 keys holded by u, simultaneously switch on your mobile.
The headset icon always appear in my nokia n70 and cannot remove and when i connect my headset ... it doesn't work . with or without headset the headset icon always appear in my screen .
this setting can be adjust by the phone settings. you just setup in the profile to answer automatically, and you will have a 5 second delay automatic answer.
hi,
please contact nokia service centre for further assistance because the headphone symbol reveals that a headphone is connected which should not appear as you say..so please take your mobile to nokia care for service..thank you!!..
