20 Most Recent
Nokia 6170 Questions & Answers
Nokia 6170 security code?
imei:351860018288243 model 3220 rh-37
provider: smart
philippines
can anyone help me with my restriction problem?
1/20/2024 9:28:32 AM •
Nokia 6170
Answered
on Jan 20, 2024
How to reset security codes nokia 6170
Go to "access codes" in "security" menu of the "settings". There you have the provision of resetting the security code by providing your current security code. It's simple. Best Wishes.
11/5/2010 5:33:58 AM •
Nokia 6170
Answered
on Nov 05, 2010
When it turns on the screen comes on but dim, then
Flip phone normaly riben cable problem. Some time you can't see if that riben cable is broken except use microscope minima 10x zoom. I suggest you to change the riben cable. Riben Cable for nokia 6170 and 7270 is same.
8/4/2010 4:44:57 PM •
Nokia 6170
Answered
on Aug 04, 2010
Getting a mud soaked nokia 6170 to power up
Maybe some of component loose touching on surface of pcb. you can try this solution, but must have some tools to do that. Pill out the membrane keypad, by using the blower or heat gun, try to heat overall pcb. don't put so closed, for alternative tool if you don't have blower, i think you can try using Hair Blower. But carefully handle.
8/4/2010 4:36:19 PM •
Nokia 6170
Answered
on Aug 04, 2010
Menu butoon of 6170 is not working
for your info, keypad ic for nokia 6170 fix to near of angle p.c.board assy, if you have drop before, as my experience before, i found so many keypad ic crack. if you see that sim ic likes chip off or crack on top of surface, change it with new one. This ic got 24 like solder ball bottom of ic, make sure all of solder ball joint to surface of pcb.
8/4/2010 4:22:41 PM •
Nokia 6170
Answered
on Aug 04, 2010
Nokia 6170 wallet code
its a user defined and by defaly there is no code. if u have put the code before and forgot it. kindly contact the local phone workshop to get the firmware ( software ) reinstall .
3/25/2010 11:21:36 AM •
Nokia 6170
Answered
on Mar 25, 2010
SGH-A412
Blue tooth is your best friend.
www.tigerdirect.com
1/27/2009 4:56:28 AM •
Nokia 6170
Answered
on Jan 27, 2009
Restriction code for Nokia 2690
It is normally recommended you Don't post your IMEI on websites. It is a security code for that phone.
Usually the IMEI number has to be reset by your network provider. It normally cannot be done directly from the handset. Did the handset accept the new sim card. Some handsets can be locked to a specific network and changing network can stop your phone from working.
