Saya punya masalah LCD Proyektor NEC VT460 sbb: Led power sudah nyala orange, kok tidak mau nyala saat tombol On/STAND BY di tekan.
SOURCE: NEC vt460 Projector have a ghost problem on the screen
Hello
Pls Service the LCD Panels of the Projector, Also check the Fly-Eye lens, just next to Lamp unit. This will solve your problem. if it's not then the only solution is Replacement of LCD Panels, But Must check or replace the external RGB Cable first befor doing all this exercise.
SOURCE: NEC VT460 issue with RGB
Dear please set the resolution of your PC or Laptop ,so that it can give O/P at same resolution as projector. For issue regarding resolution supported by Projector go through manual of Projector.
regards,
rakesh Kumar
Network Support Engineer
SOURCE: We want to do the
There are no dealers in Hydbad as per the site below. Given below that is the cust Helpline number and email address.
http://www.necindia.in/m_local_dist.html
Customer helpline number : 011 - 61101010
Our contact center timings are : 9am to 5.30pm, Mon to Fri
Our support id is: [email protected]
