SOURCE: compatibility
Yes both of them are compatible, The 8500 GT uses a PCI X16 slot which is available on the m2n-mx motherboard.
Check these 2 links
http://www.amazon.com/Geforce-8500-Pcie-256MB-2PORT/dp/B000RKS3MU
http://reviews.cnet.com/motherboards/asus-m2n-mx-motherboard/4507-3049_7-32045049.html?tag=mncol;psum
SOURCE: Asus M2N-MX se plus board.... compatible with GF
maybe it is an AGP slot, there is also a pci-e slot.
SOURCE: Asus P5GZ-mx compatible graphics cards
Basically, any graphics card is capable of being compatible with this motherboard. I had some difficulties for a while until I figured out you have to MANUALLY set it to use your PCIE 2.0 GPU output.
How to do this is to set your jumpers to external output only. First thing you'll want to do is update the BIOS on the motherboard (Which you can do by getting "Asus-Update". Find it on google, easy to use, just make sure your computer doesn't crash during the BIOS flashing.
Afterwards, set the jumpers to use your PCIE-2.0 slot. Took me a little while to figure this out, and it's a little hard to explain.
Above your PCIE-2.0 slot there are 5 little blue 'plastic-like' things. Those are your jumpers. Take them out and insert them HORIZONTALLY as such:
Basically, make sure the jumper things are connecting the little drawing there. They HAVE to be horizontally inserted, otherwise this WILL NOT WORK. Just plug in your monitor to the graphics card's output, and you're good to go. Hopefully it works for you.
SOURCE: asus m2n mx se audio drivers
CLICK HERE in the top left type m2n-mx se and click search info it will bring up results on the right click you corresponding model and then it will ask you for a OS select your OS and click OK the select audio and click on the download link. or simply CLICK HERE
SOURCE: my motherboard cd of asus m2n mx se series nvidia is broken so
You can call Asus and buy a new CD at 1-812-282-2787 US.
Or you can download the drivers directly from Asus and burn the drivers to CD/DVD-ROM disk. Link to Asus motherboard M2M-MX SE;
http://www.asus.com/Search.aspx?SearchKey=m2n-mx%20se
Cheers'
Mike
