Treatmill stopped running.
Precor Error 44, Un-commanded Lift Motion
Probable Cause
1. Intermittent or bad connection in the lift position sensor(potentiometer).
2. Lift position sensor (potentiometer) is bad.
3. Lower PCA is bad.
Corrective Action
Precor Error Code 44
SOURCE: The quick start button does not do anything,
You would need to replace the keypad overlay on the console.
SOURCE: The belt on my Precor
Error 22 means the drive motor is diconnected. you will hear the fan and other parts make noise but check the red and black anderson connection between the main circuit board and motor.
SOURCE: I have a Precor c956i
Removethe red "STOP" cover. The cover may pushes against a switch. If theswitch moves too far down and rests against the cover, it will be stuck in alock position causing the error message. To remove the red STOP cover, removethe few screws behind the console. When the front cover is off, turn it overand unscrew the two screws that hold the red stop cover. Then push the coverout through the FRONT. Do not attempt to lift it out by the end with the screwholes. It will not pull out that way. Test the machine before screwing thepanels back again. The message should no longer show STOP KEY. Test the visiblewhite small switch that you uncovered by removing the red flap. The messageshould stop when you press the switch. If theproblem still exists then open the console and check under the magnet holderfrom inside you may see rust ire broken cable there, if you find thisthen you may have to replace it. Hopethis will help you.AV
