SOURCE: bypass for video on a kenwood ddx-512 car dvd player
On the wiring harness there is a green parking sensor wire (PRK SW) that you have to hook up. All you have to do is ground that anywhere on the chassis of the car then youll be set.
SOURCE: kenwood ddx-6019 password
Contact Keenwood, they may make you send it in and charge a fee. Goodluck.
a friend of mine who is into bypassing stuff...found this method from sumwhere and it worked on my system...
u need to reset the system first by pressing the small button right next to <ATT> using a ball point pen or something pointed...
once it reboots,
keep the <SRC> button pressed till the display goes off, then while keeping the <SRC> button pressed, press the <ATT> button for 3 seconds, while keeping both of these pressed at the same time, press the small <RESET> button next to the <ATT> button using something sharp...
this hard resets the system and it reboots to a blank screen,
press the <SRC> button once and you have all the options working...
anything else, lemme know...
[email protected]
i think you find some softuare on ebay to unlock your radio....i m not 100% sure but you can take a locke
