Re: Honda mower engine oscillates when idling. Check it...
The carb needs to be cleaned. The main jet and nozzle are the areas to pay attention to. The main jet screws into the carb in the same spot that the float bowl screw goes into. The nozzle sits above that and if you tap the carb (carefully) on the bottom once the main jet is removed the nozzle will drop out. Use a small piece of wire to clean all the small holes in the jet and nozzle. Make sure they are open and free of clogs. This is a common problem with all small engines.
Update: 07/10/2018 Jim replied that He found (the shop did)a weak or partially shorted out ignition coil. Wow, This used to be a common problem with the old pull to start mowers way back in the 50-60's. Bad coils were common as they were hand wound and open. Modern coils are usually encased in plastic to prevent water from entering wire winding. I'm wondering where they are getting coils from? * Oh, Tip;Hard starting engines can be easily started by using "Engine start" spray (carberator cleaner)as they sell it at NAPA,Walmart, etc. You can find a lot of vids on how to start a generator that has been sitting around. No need to remove spark plug. Just a shot into the intake will do the trick. (Spray will also clean the plug if you do happen to pull it out to check. Aloha, ukeboy57
if it's old enough you'll have to get the kit. 06225-vh7-305. on the trans there's a lever that the cable attaches too. if it's a barrel type it needs updated. if it's a loop style then its the newer style. If you don't have the proper tools you might want to have a Dealer do the work. will save you the headache.
? 13:31
https://www.youtube.com/watch?v=QTDLBZonjvo
Aug 14, 2014 - Uploaded by NutzAboutBolts
1996 Honda Accord rear engine mount Tools: Impact wrench 3/8 ratchet ... Wat size are those bolts in the rear motor mount, I have to replace them ..... 1998-2002 Honda Accord 3.0 V6 Spark Plug Replacement - Duration: ...
? 5:28
https://www.youtube.com/watch?v=jCIBNq0jg0U
Oct 17, 2013 - Uploaded by Chandler Cox
How to Replace the Motor Mount on a Honda Accord .... I have 2001 Accord and engine/front vibrates when car is idle. .... onreplacing and removing rear mounts for this year and model car.... 1998-2002 Honda Accord 3.0 V6 Spark Plug Replacement - Duration: 12:48. by CharlietoKind 103,467 views.
? 29:43
https://www.youtube.com/watch?v=vkO19Ux9q9M
May 30, 2013 - Uploaded by klowny1969
Step by step honda transmission motor mount and transmission... 2000 2001 2002 2003 2004 2005 engine mount how to replace install check change ... MAKE A VIDEO TO INSTALL THEREAR MOUNT MOTOR PLEASE .
per this address "http://www.obd-codes.com/trouble_codes/" p0505 is a "IAC (Idle Air Control) System Malfunction" it gives some good suggestions to look at to find a solution for your problem.
It would depend upon WHERE in the world you are located but you should be able to contact your nearest Honda Mower dealer or do an internet search for >> "hrx 537 honda parts" << and it will return quite a few places both on-line and in-person place where you may purchase them
