Installed the lifetime basketball hoop in ground system and when we play there is no bounce off the backboard. why?
Well it is probably a cheap backboard then. sorry
This is for model 90228:
Under the piston (silver) there should be a small circle. Get a flat head screwdriver and pry the circle out and there should be a sort of button. Apply the grease that comes with the parts to the shaft of the button and use the trigger normally.
the backboard vibrates alot when the ball hits it almost like it absorbs the impact and doesn't let the ball bounce and rebound properly.
do not have instructions for the 1553 have two brackets for the backboard and they look like they to be bent at an angel. not sure mine are straight.
no bounce of the backboard is the backboard stiff
need instruction manual for lifetime's "shoot case bee ball" hoop
