Just bought a 12 hp roper belt for cutting blades was missing anyone know belt size it has 36 inch cut
SOURCE: craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
SOURCE: won't engage blades to cut lawn
Is the belt on the pulleys ? If so your cable is broke its what engages deck belt
SOURCE: 42 inch Craftsman blades won't engage
is the belt spinning & smoking when blades are engaged or the belt won't spin if the belt spins but blades wont go then there is something stuck under the deck or the bearings are gone out do to not being greased
SOURCE: duel blades on craftsman riding mower cut unevenly
check the front tire air pressures then for a bent blade
SOURCE: my craftsman lawn tractor 42
most likely you are in reverse with the key in the mow forward position only. turn key to the reverse mode or put the gear selector to forward mode.
Select Index Numbers here:
2 Asm, Jshaft Housing Head W
3 Q2 Pulley , 46"
4 Shaft, Splined Jacks
6 Nut, Pulley
7 Hub, Blade Adaptor
8 Q4 Blade 46" Mulcher
9 Washer, Bellevile(ard
10 Washer Hardened (ard
11 Nut Hex (ards)
12 Screw, 3/8, 16X1.25
24 Rod Belt Guide
25 Belt Cross Drive Ja
26 Belt Primary 46" J
34 Bracket Cover
35 Bracket, Pulley Cover
36 Qx Lburg# 094605E700 -INACTIVE-
37 Use Lburg# 093349 Zi -INACTIVE-
38 5/16, 18 Hexwdfllk Wh
39 Screw, 5/16, 18X.75HH
40 Cover, Pulley Right
41 Screw, 10, 16 .190X.62
72 711327
72-1 Wheel, Gauge
72-2 Bolt, .500X3.275HHSH3
72-3 Spacer, Slev .515X1.
72-4 Nut, 3/8, 16 Hxctrlkj
72-5 Qxcolor Code Require -INACTIVE-
79 Pin Detent Ring (DP5
80 Asm, Mulcher Plug 46
81 Bolt Carriage (ards
82 Nut, Wing (ards)
89 Zerk, Grease Fitting
