Plasma tv
SOURCE: Samsung PN50A550 Plasma TV started clicking on
hi i have replaced power controls boards in more than a few of these & this needs to b done by a expert .
Testimonial: "I figured it would be something along that line-Here in AK, repairs can be costly-but I'll get a pro. Thanks!"
SOURCE: samsung plasma 50in PS50B550 clicking noise
The clicking could be a loose connecction of the power plug or frrom the main power unit of your TV. Remove your plug and see the ends for burn outs, if so clean and use a different outlet. If not open the set after disconnection and check your main power supply unit for loose connection particularily in the surge protector, the main capacitor, the main drive, diodes or connectors. Wait to hear the sound and use a long insulated rod as a probe to confirm the origin of the sound. Solder or replace the damaged item. Hope this helps . Good day
SOURCE: When I turn the samsung pn50A550 plasma tv on, it
Inpsect the power supply caps for bulging/leaking tops first, also chek the caps on the sustain boards. Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Post back what you find.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
SOURCE: my samsung 46" plasma tv
On your Plasma tv you have cooling fans on the back side you will need to check to make sure that they are running. Lay your tv on the bed take off back cover (it's not hard) and used some air-in-the- can to remove dust from the back! If you need a fan go to Partstore.com (1-866-925-PART)
Thanks,
Wbigtodd
