Procedure and timming marks
SOURCE: Need timing marks for 93 chevy 454
Under the hood on the emissions decal should say what degre the timing should be set at. ther is a one wire plug that is brown with a black stripe u need to un plug befor seting the timing with a timing light . u can usually find that under the glove box or behind wher the fuel pump relay is . i think the timing is set at 4 degres on the timing pointer but look for the decal first too make sure im right.
SOURCE: Skoda Octavia Ambiente 2004 1.9 tdi, automatic
problem one is the timer control for the heaters ,also check the heaters that they are working ,oil problem ? look under the rubber boot that goes over the oil switch ,pull it back and if oil under the cover renew the oil switch,these motors do suffer from heater light flashing on and i know people have spent megabucks trying to cure it ,its a fault with dash and printed circuits ,but the heaters are not coming on i know because i have driven one with the heater circuit light coming on and i had a extended light on a long wire and the heaters are not coming on ,ignore it just renew the faulty glow plugs,as for EGR valve just pull teh vacumn pipe off the ERG valve and leave disconnect ,more hassle than its worth changing it ,you could end up with a ECU computer .Still a nice reliable motor though and economical
Testimonial: "Thanks for your usefull answer. Afer I stop the engine 2 times from EGR valve, both board alarms have been reseted. What does it mean? Thanks again."
SOURCE: front brake pads 2005 Skoda Octavia 1.9td
I have no idea what a skoda octavia is, but I know brakes are brakes. You have 2 bolts holding the pads in a slide, the bolts have threads only at the top, the rest is the slide, pull those bolts, if that doesn't release the slide, take out the 2 bolts holding the caliper on there, pull the slide out the other way. replace the pads, make sure they go back in the way came out. Put the bolts back on, tighten them up, you should be all set. The pad thickness sensor is just a ground, when the wire hits metal, it turns on a light, It should go off when it is not touching anything. You should have squealers on there too, they give an audible screech telling you it is time for some new pads. Hope this helps.
