Samsung GX-1S Digital Camera Logo
Posted on Dec 30, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Gx 1s memory card not formatted
I took the photos off my son's memory card for him and then gave him the memory card back. It now says card not formatted when he puts it in the camera. Tried to use the Format menu to format the card but it doesn't let me - just says 'card not formatted'. Any ideas please?
Ada Copper
Level 2:
Guru:
  • Expert 40 Answers
  • Posted on Jan 02, 2018
Ada Copper
Expert
Level 2:
Guru:
Answers
40
Questions
0
Helped
17284
Points
404
Try CMD command to fix the corrupted SD card. Or use RePicvid Photo Recovery for Free to recover pictures.
pontelemon
Level 3:
  • Master 538 Answers
  • Posted on Dec 30, 2017
pontelemon
Master
Level 3:
Answers
538
Questions
0
Helped
175927
Points
1223
Get USB card reader and Requva or similar software to recover card. Look like card is going bad……
  • pontelemon
    pontelemon Dec 30, 2017
    Most likely the card gone bad. Get a card USB reader and see if you can recover pictures via PC/Laptop. Use any Memory Card recovery software like Requva or other.
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Dec 26, 2007
SOURCE: Memory Card Locked
There is an option to lock the memory card, so here's what you do. Open battery slot<remove card<there is a lock tab just switch it to unlock. tab is on side of card on SD card
Anonymous
  • 24 Answers
  • Posted on Jan 11, 2008
SOURCE: Samsung S630 Digital Camera, Card Error and Format Error
you have several options:
1. see in the specification details of your camera what memory card is compatible for camera. for S630 it is SDHC/MMC/SD card (Up to 4GB Guaranteed). see if you're using memory card within this capacity and type. If you're using a different memory card type and capacity, try to use memorycard that is compatible with your camera.
2. try to use memory card to other devcie like cameras, cellphones and other devices and if it still has error problem, your card may be the one defective. use other cards.
3. try to take pictures without using memory card. use only the internal memory of camera. if camera still display this error meassage, camera needs service.
hope these options solve one of your problems. c",)
Anonymous
  • Posted on May 22, 2009
SOURCE: SD memory card will not format in a Samsung Digimax 301.
I own a samsungDigimax 301, 3.2 mpi camera. When I inserted an SD card in the slot, the screen read " card error". Could you guide me as to dealing with this problem so that I may use the camera to take pictures this weekend? Thanks. Mathew.
Anonymous
  • 3006 Answers
  • Posted on Mar 23, 2010
SOURCE: I bought a 4GB Memory Card for my Samsung Digimax
Your problem is that your camera only takes standard SD cards up to a maximum of 2GB. The card you have bought is likely to be a 4GB SDHC model. SDHC is a later development of SD; SDHC compliant devices can still use older SD cards, but SD-only devices cannot use SDHC. This is a hardware limitation so there is no way at all to use an SDHC card in your camera.
Note that if your 4GB card is definitely an SD and not an SDHC then it's still incompatible with your camera: very few standard SD devices were ever made with the firmware and hardware to handle the different memory addressing architecture used by the larger capacity card. Some cameras did have firmware updates to allow the larger SD card to be used, but yours is not one of them.
Your only fix is to sell your card (or keep it for another device) and to buy a regular SD card no larger than 2GB maximum capacity.
I trust that my reply has answered your question fully, please take a moment to rate my answer.
Jonathan
  • 85 Answers
  • Posted on Aug 10, 2010
SOURCE: I just bought a new
The largest SD card you can use in your Samsung NV10 is 2GB. thats why once you insert the 8GB sd card its shows card error or need to fromat.
FYI. for every digital camera there's a compatible memory card and you can see from the box or manual and Its writen SD or SDHC.
goodlukc and thank you
Testimonial: "Thanks, I didn't know that! Now I'm just annoyed at the store who sold me the 8GB memory card. Guess I'll have to save that one for later."
2helpful
Help, my16GB SD Card can't be opened nor formatted but it can be read.
Since I was also facing the problem, where my SD card got corrupted and was not able to access. finally I came across the software to recover corrupted SD card which helped me to recover my lost photos and here is the download link
1helpful
2answers
Half of picture is grey
I'm not an expert, but when I had this happen, I took out the SD card and put it into a card reader. Then download a SD card recovery software to retrieve my lost pictures.I have a professional one called Tenorshare Photo Recovery on my PC that can recover lost,corrupted,deleted or formatted pictures from memory card.Get it from:
http://www.any-data-recovery.com
Hope this help!
VL-Z3 will not record video
Having the same problem. I got this from a friend who also gave me a blank cassette. I could record on the cassette without any problems, but when it comes to using a memory card, it said the same thing. First it said Format Memory Disk, which I already did. Then when I tried to record, it says Please Use Photo Button. My son's graduation is coming up in 12 hours and I still haven't found a solution!! If someone could enlighten us on how to fix this, it will be greatly appreciated.
I purchased a memory on sunday - took pictures and downloaded to computer but did not delete from camera. today i took more pictures and reviewed them - all was o.k. before downloading onto computer, i...
Take no more pics until you've recovered your photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that may help you recover your photos. This article reviews and outlines several of the better ones. Now after you've recovered your photos, consider formatting the card in the camera to prevent this from happening again.
12helpful
7answers
Can photos be retrieved once the SD card has been formatted? i had selected the "protect option" & those photos still were deleted.
I had success with this
1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download photo recovery software, recommended one is 001 picture recovery (simply because i was using it and it worked)
http://www.001-software.com/picture-recovery/
4. Install and open the photo recovery program, select your memory drive, and click 'Start' button to start scanning process which will find your deleted photos.
3helpful
My son took the camera from my handbag and dont know what he did with it, when i start it first a foggy pic appears and then the screen turns blue showing D 5f08 and 5e02.and the lens also shuts in
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success
1helpful
Took a few photos, switch off, 5 minutes later switched back on, blank screen but can view playback and menus
Hi, I just bought a camera Samsung GX 1S, and also a GB SB card "High Performance". Every single time I turn on the camera comes a mesage indicating the card has memory problems. I formated it but the...
The card you bought for the camera is not compatible with your camera! (just because it fits and looks the same does not make it a match!) try useing a regular sb card and return the high proformance card!
Jan 13, 2009 • Cameras
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
