Buzzing y sus gets louder when white back ground comes on reminds me of old tube tvs,
SOURCE: polaroid lcd hdtv 27" buzzzz
thre are several components that can make a buzzing sound, especially a bad power component or capacitor. check the capacitors to make sure they are installed in the board correctly. the stripe on the cap must line up with the white mark on the board under it. remove the back panel lay the tv down on a blanket turn it on and see if you can isolate the noise component by ear up close. and visually check for swollen capacitors the top will be pushed up round if bad if good it will be flat on top. warning if tv is less than a year old make the place you bought it replace it. so you dont void the warranty.
SOURCE: Y SUS Board for a gateway 42" m303
if you check the 15v pin on the board You probably will find the 15v shorted to about 5ohms and one of the two large units on the board is shorted 4921QP1002B. I myself am looking for that part. If you bought a new board can I get Your board for parts?
SOURCE: Vizio GV42l buzzing
Vizio makes an ok LCD, but if you notice they no longer make plasma. they stopped last year. Anyways. the buzzing sound is semi serious, it sounds as though you have a capacitor leaking. It is best to get it fixed before it goes out all the way, with it buzzing it will be easier to identify. Best of luck
Testimonial: "Quick response, i will check it out asap"
SOURCE: 37inch Vizio TV making buzzing sound from back
my tv is new too and also makes a buzzing sound and i turned the DCR off and it worked to thanks for the help!!
Solved heat sink lose
