Maytag MZD2766GES Side by Side Refrigerator Logo
Heidi Zlab Posted on Dec 22, 2006
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water leaking onto floor
Refrigerator was moved to another room to replace damaged wood floor due to break in water line on washing macine. Floor is replaced and refrigerator placed back in kitchen. Refrigerator was only unplugged for about 5 minutes each time it was unplugged. We turned water back on to use the ice/water dispenser. Two days after, noticed water on floor coming from front of refrigerator. It is not coming from water line tube. Ice is building up on bottom of freezer. I remove ice and it builds up again. We shut off water line to freezer. All ice is out of ice maker. Ice built up again on freezer floor. Can you help ??? Don't want to ruin wood floor with water again. angels
  • 8 more comments
  • sirimhorse Nov 08, 2007
    I've had the exact same problem with my bottom mount Dacor Epicure refrigerator. My unit leaks every day or so from just behind the freezer door seal (from under the unit, but the front half of the unit). I've had warranty repairmen out five times. Each time, they claim some other part is the issue and needs to be replaced. Each time, the replacement does not fix the problem and the unit continues to leak. Dacor has refused so far to replace the unit and now my new wood floors are warping in the spot where the leak happens.
  • p7350 Dec 27, 2007
    Noticed water on floor in front of refrigerator. Bottom of freezer has ice build up.
  • winmond May 14, 2008
    water on the floor in front of and the refigerator and ice build in in bottom of freezer. There is no rhyme or reason that I can see ( not when ice maker refills, or when using water dispenser etc.)
  • bcgs Jul 25, 2008
    Water is leaking onto the bottom of the freezer. Once enough water has filled the bottom of the freezer, it freezes and additional water overflows and comes out the front of the freezer. In the beginning we thought we weren't closing the freezer door completely, but this turned out to not be the problem. We still have not solved it. I just installed new hardwoods in my kitchen and I don't want to bring in the fridge until it is fixed. Anyone know what the problem is? I'm thinking there is a problem with the self defrosting feature.
  • Anonymous Sep 02, 2008
    Ice built up on bottom of freezer. Leveled out frig and deiced and ice came back.
  • brynfrd Oct 07, 2008
    Same problem bottom freezer of a LG
    no ice maker I belive leaking out the freezer
    through the front door from the solid Ice on the bottom
    thinking maybe a drain plug which I can not see
    or a pluged air vent between the two compartments.
  • Anonymous Nov 29, 2008
    Magtag refrigerator water on floor
  • Anonymous May 05, 2009
    Water runs out from underneath the refrigerator. It happens about 2 or 3 times a week. A little less than an quart. Flows out pretty quickly then stops.
    Helpp
  • Anonymous Mar 16, 2014
    My refrigerator MOFFAT MRF1528T-7 often has freezer odd fan noise. but when I open the cover in the freezer, I don't find any ice build up and the fan works well and no big noise. When I put the motor and fan back, recover them. After several days, the odd noise will come again.
    Thank you very much for any help!
    Have a good day
  • Anonymous Mar 31, 2014
    Refrigerator compressor has hissing sounds when starting up and shutting off. No upper and lower cooling when we turn on the thermostat the compressor comes on with the cooling fan in the rear of the frig and the fan in the freezer and then the hissing sound like water going thru a orafice either from the compressor or the 3" x 1/2" copper tube the sound diminishes in 5 minutes but only very slight cooling in refrig only, then when we turn thermostat off the compressor and cooling fan shuts off and the hissing noise from 3" x 1/2 " copper line with multipal tubes connected to it comes on for about 5 minutes and slowly dimmishes away. we have the back cover removed all looks good. Also Can not find defrost switch. Is this worth the price of repair when we can buy a new refrig for $1,000.00.
Anonymous
Level 3:
President:
  • Master 878 Answers
  • Posted on Dec 22, 2006
Anonymous
Master
Level 3:
President:
Answers
878
Questions
Helped
1202229
Points
3312
Angels, sounds like your defrost drain is frozen over. When the refrigerator is going into defrost it's draining through the front instead of the drain pan. You can remove the shelves and peel off the back cover and clear the drain by pouring hot water on the frozen drain hole. If you have a baster of some sort you could try to squirt the hot water through the venting on the bottom of the panel. Another way to to point a hair dryer on the drain hole. The best method is to remove the shelves and panel and make sure the drain is clear. Catriver..post back.
Robert Hinsman
Level 1:
  • Contributor 53 Answers
  • Posted on Jun 25, 2008
Robert  Hinsman
Contributor
Level 1:
Answers
53
Questions
Helped
33505
Points
96
I had this same problem with my Viking unit. Bottom mount freezer refrigerator.
Don't what model you have. however, After the repair people told me it was going to be 100 just to say hi, I took matters into my own hands.
After taking apart the freezer back wall i found a drip hole just behind the wall. after breaking up the ice. Put a hair dryer on it and managed to melt all the ice and from the bottom I found a few piece's of frozen bean segments caught on the hole.
This clogged up the hole and stopped the water from draining down to the defrost pan below and backed up and the ice would form and as it moved to the front of the freezer door it would drip out and wreck the floor.
After taking care of this and making darn sure the freezer never had anything left on the bottom in there. I save 650.00 and it only too me 2hours. on top of that I figured out how to remove my ice maker when i started having trouble with that.
If there is a drain hole behind the wall that could be your problem.
good luck
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 29, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
10586
Points
My GE side by side drain tube clogs occasionally. Remove the ice in the compartment, pour a bout 1/2 cup of water in the drain, then use your little finger like a plunger in the drain.
Mine clears on the 1st or 2nd attempt.
Anonymous
Level 1:
  • Contributor 2 Answers
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
11445
Points
7
Just had a similar problem with a Samsung model. Water freezing on shelves, running down inside of door and freezing, clogging ice outlet spout, water on floor. Called out engineer. Before engineer came was standing beside fridge when wife closded door. Thought it sounded odd. Door being held slightly open by a pack of frozen food. It looked closed but was letting warm kitchen air past the seal. Checked the obstruction and the problem vanished. The ice hopper had been frozen solid. Stopped the engineer calling that was two weeks ago and all is well
Anonymous
Level 1:
New Friend:
  • Posted on Aug 15, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
10586
Points
Yup, I had same problem with our Viking bottom freezer refrigerator model # VCBB363LSS. Ice built up on bottom of freezer and eventually started leaking out the front of the freezer onto the floor. The cause was a ice-clogged defrost drain in the back of the freezer floor. In order to fix it you have to either turn off the refrigerator for over a day to let everything melt or take off the back panel in the freezer, chip away or melt all the ice with a hair dryer and then repeatedly poor boiling water down the drain hole until it drains (out into a pan under the fridge.) The second was a bit of work, but took
Anonymous
Level 1:
  • Posted on Sep 02, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
10586
Points
I had ice blocking the drain hole underneath the coil in my Kenmore but the drain hole is not visible until you remove the inside back panel that exposes the coil and the drain .Be careful, I broke the panel getting it out because of the ice build up on the bottom of the freezer.
Anonymous
Level 1:
New Friend:
  • Posted on May 20, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
10586
Points
I have a Maytag side-by side fridge freezer. Ice had built up at the bottom and water used to come out the on to the floor. read all the solutions here- were a great help. Switched off the powers supply, Took out all the ice, opened the back panel and found the drain hole was iced. Removed the ice, but the water would still not go through. Opened the panel behind the refrigerator, saw the pipe coming from the drain to the tray where the water collects, removed the L-shaped rubber connection between the drain pipes, removed all the muck that was blocking the drainage, using a flexible cord, poured hot water down the tube to rinse off any muck stuck inside the tube, put it all back together and it worked.
A
Anonymous
Our lg refrigrator on floor front of refrigrator
give me solution what i do?
Anonymous
Level 1:
  • Posted on Jun 09, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
10586
Points
Continued fro catriver My Amana's drain tube (discharge end) is not visable from underneath without a mirror and it has a nipple arrangement which is flat, making it easier to clog up, even after I got the drain hole thawed, the water wouldn't drain until I squeezed the discharge end and broke whatever blockage there was. I continued to run hot (not boiling) water down to clean it out and I made notes to myself so I will remember the process, because I'm sure it will happen again.
A
Anonymous
I have the same problem. After searching the web, it looks like a blocked evaporation tube (or something more sinister!)
3 Related Answers
Anonymous
  • 3 Answers
  • Posted on Feb 04, 2009
SOURCE: maytag side by side, bottom freezer compartment had daily ice build up
I’ve had my Maytag fridge for 8 years. But only this week did the same problem show up as cathy824 and lew223. When I poked a drink stirrer into the top of the drain hole, it was hard as a rock. Not knowing why condensate from the coils was not draining into the hole and tubing that would empty the water into the pan evaporator on the bottom of the fridge, I took everything apart in the back and messed around with the black rubber elbow at the other end of the drain plug. I shouldn’t have bothered, because what I finally did was to pour boiling, boiling hot water over the drain hole to melt the ice and gunk that was frozen solid in the drain tubing. While I was doing that, I poked the stirrer into the hole, washing the gunk down the drain and into the very dry evaporator pan. Keep pouring hot water into the drain hole until you’re satisfied that water can flow freely into the pan.
That solved the problem of condensate water freezing on the bottom of the freezer and running onto the kitchen floor. Thanks to lew223 for the fix! The fridge should be good for another 8 years now.
Anonymous
  • 72 Answers
  • Posted on Jun 11, 2009
SOURCE: leaking water onto floor at front of refridgerator
could be a leaky water valve
Anonymous
  • 86 Answers
  • Posted on Apr 20, 2010
SOURCE: My Maytag side-by-side refrigerator/freezer Leak
There is a pan and drain hose under the freezer coil that is there to catch any water when the freezer goes into defrost. I feel strongly that is where you will find your leak.
I hope this helps.
Water leaking onto floor from underneath unit,instead of into the water reservoir.
It's not unusual for a refrigerator to drip a little water on the floor after you replace the water filter-air trapped in the water dispenser system can make the water dispenser drip enough to overflow the drip tray below the dispenser. You can fix it by streaming a gallon or two of water through the dispenser to eliminate the trapped air.
If water drips on the floor from the back of the refrigerator, a leaking water inlet valve or cracked water system tubing could be the cause. A clogged or cracked defrost drain tube could also cause the leak. Defrost condensate water collects in the drain pan at the bottom of the refrigerator so a cracked or overflowing drain pan can also cause water to drip on the floor behind the refrigerator. Check the drain pan for cracks and clean out any foreign objects that may be inside the drain pan.
Excessive frost caused by a leaking door seal can also cause the defrost drain pan to overflow. Check the door gaskets and replace them if damaged.
I have water on floor under refrigerator.There is no water supply line to this frig.
If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.17 May 2013
SOLVED: Water leak in refrigerator? - Refrigerator - iFixit..or go to this link might help you as well....
water on floor under refrigerator Google Search
Water leak onto floor
There should be a drain pan that is deposited into, however some will crack or be moved out of place causing this.
Water drip on to floor from rt.rear. profile side by side
Tube may be a ice maker supply line. You can replace it at any home depote
Water leaks out on the floor from Kenmore refrigerator mdl 253.7482240h
Be sure the drain line is clear from the bottom of the freezer to the drain pan.
My DFF1170W Top Freezer Refrigerator is leaking on the floor, what should I do?
If you have a ice maker or water dispencer check the water line conected to the back ! If you move the fridge alot some times the water line can get damagged.
1helpful
I have a Maytag MSD2556AE Side by Side Refrigerator/Freezer. I keep getting a puddle of ice in my freezer and water leaks out of the freezer onto the floor. All this happens in spite of the water line to...
Sounds like you have a frozen drain line. I would unplug the unit at let the drain line thaw. This would be the easiest way to rectify the issue. Leave both doors open for 24 hrs. Hope this helps _MJ_
Whirlpool frig won't fill the ice maker sounds like running but no watersomeing into it
If you hear the sound of water at the end of the harvest cycle, verify the plastic water line on the back of the refrigerator has not come out of the fill tube or water valve. Aslo verify it is not cracked and leaking. If so, water would be running onto the floor and damage to the floor could result.
Water leaking onto floor when defrosting automatically
There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are cased by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
[email protected]
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
SEA BREEZE TIP's
2helpful
2answers
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
