HP LaserJet P2015 Printer Logo
diya menon Posted on Nov 21, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HP LJ printer printing slowly
HP laserjet 2015DN printer connected through standard TCP/IP printing very slow.Through USB, print coming fast.I checked spooler service, updated driver & reinstalled the same.But problem not solved.Please help me.
Shadi Abed
Level 2:
New Friend:
  • Expert 72 Answers
  • Posted on Jan 05, 2010
Shadi Abed
Expert
Level 2:
New Friend:
Answers
72
Questions
Helped
25601
Points
164
Try to change the driver on the network definition
HPlaserjet 2600n without IP
INSTALLING A NETWORK PRINTER These instructions generally apply to all network printers with built-in network cards (print servers) such as HP LaserJet printers, IBM Infoprint laser printers etc. This example is for a network HP LaserJet printer. To install a HP printer (with built-in Jetdirect print server) as a network printer on a wireless network . You need to do the following -
1. Open the printer\'s menu and enable the Network Card - these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP\'s are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer\'s network configuration accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP\'s printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printer prints correctly.
Install the HP printer driver on every computer on your network and configure the printer\'s TCP/IP port as previously detailed. Do a test print page to check the printer.
You can now print from any computer on your network.
3answers
US-4A Keyspan USB Server
if urs is a 3 in one u wil have scan and copy functions also included in this sir.
is urs a 3 in one?
Set up wirelessprinter hp
Wireless printer configura
These instructions generally apply to all networkprinters with built-in network cards (print servers) such as HP LaserJetprinters, IBM Infoprint laser printers etc.This example is for a network HP LaserJet printer.To install a HP printer (with built-in Jetdirect printserver) as a network printer you need to do the following -
1. Open the printer's menu and enablethe Network Card - these print servers use a static IP address therefore,configure the IP address of the network card so it matches the IP range of yournetwork. Eg. If your IP's are 192.168.0.*** then set the network card to a highnumber say 100. (This is to prevent a conflict with the router issuing the sameIP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IPaddress range that the router issues to the computers on your network andconfigure the static IP address in the printer's network configurationaccordingly.
2. Install the HP printer driver onyour computer/s using the LPT printer port.
3. Connect the printer with a LAN cableto the network hub/router.
4. Click on Printers and Faxes - rightclick on the HP printer and click on Properties.
5. Click on Ports and click on AddPort.
6. In available ports - click onStandard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IPaddress of the HP's printer IP address.
8. Click OK and tick Enablebi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printerprints correctly.
Install the HP printer driver on every computer on your network and configurethe printer's TCP/IP port as previously detailed.Do a test print page to check the printer.
1helpful
Slow printing hp laserjet 2320 mfp
I have just come up against this issue my self, 4 x CM2320's installed on 150 PC's. After a lot of head scratching I dug out wire shark and did some network analysing as I thought it was a network issue. Turns out it sort of was, the HP software installs a custom network print port, this print port scans the network to see if the printer has changed its IP address BEFORE it tries to spool...!! The solution is to create a new network port and put the printer on that. Originally it took well over 90 seconds to print a test page, once the port was changed it dropped to 2...!!!! All PC's at this client were win XP so here's how to do it on an XP machine... Please note the printer should be on a static IP address!!!:
Start > Printers And Faxes > Right Click on the CM2320 PCL 6 printer > Properties > Ports >
If you scroll down to find the printer in the ports list you should find it has installed on a port called 'HP Colour LaserJet' or something similar.
Add Port > Select 'HP Standard TCP/IP Port' > New Port > Next > Type in the printers IP address ie 192.168.0.202 (Don't tick always print to this device) > Next > Standard - Dropdown - Hewlett Packard Jetdirect > Next > Finish.
The new port will now be in the ports list, click the tick box next to it > Apply > OK. Now try and print a test page, it should only take a second or two...!!!
2answers
I replaced a hp laserjet p2015 printer with another hp laserjet p2015 printer but it can't print.what's the problem,pls help me
This HP printer is comes with the USB cable. To install the printer software, you need to install the USB driver compatible to your printer and then it will ready to print.
1helpful
HP Laserjet 4050. Can I connect from my TCP/IP to JetDirect?
To use a printer DIRECTLY into your PC or laptop (without plugging both into a network hib, or switch), you need to use a CROSSOVER patch cable.
Can not print printer only prints test page
you have the wrong print driver installed (either wrong model or wrong OS) also check if there is a PCL or PS print driver and printer port is correct (USB, tcp/ip, Serial)
Hp lj 2015dn problem for top 2 LED standard ON in my printer
check your printer motherboard it could be the communication cable from the power board is bad or the mother board that is why it can not scan. that is the problem
Plz help me am in trouble
Network Configuration page
NOTE The Network Configuration page is only available on the HP LaserJet p2015n,
HP LaserJet p215tn, and HP LaserJet p215nw printers.
A Network Configuration page prints whenever a printer configuration page is printed. You
can also print a Network Configuration page by pressing the network Reset button at the
back of the printer
The Network Configuration page provides information about the network configuration,
including the IP address, firmware revision, network statistics, protocol information, and so
on. The Network Configuration page automatically prints when you print a configuration
page from the control panel.
ENWW Printer information pages 37
Using the HP Toolbox
The HP Toolbox is a Web-based program that you can use for the following tasks:
● Check the printer status.
● Configure the printer settings.
● View troubleshooting information.
● View online documentation.
You can view the HP Toolbox when the printer is directly connected to your computer or
when you are using a supported network connection. You must have performed a complete
software installation to use the HP Toolbox.
NOTE You do not have to have Internet access to open and use the HP Toolbox. However, if you
click a link in the Other Links area, you must have Internet access in order to go to the site
associated with the link. See Other links for more information.
To install the HP Toolbox, you must install the TCP/IP protocol and the most recent version
of the Java™ Virtual Machine on the computer. You must also install the DOT4 protocol for
all USB connections, LPT connections for Windows 2000 and Windows XP, and LPT1
connections for Windows 98 S.E., Windows Me, and Windows NT 4.0. See the system
administrator or computer manufacturer's documentation for more information about
installing the TCP/IP protocol and the DOT4 protocol.
k24674
Grand Canyon Tech
Grand Canyon Tech
