Have a Meridian M7208 was moved from one office to another office. Now phone doesn't ring on incoming calls. Is this something we will have to get someone to fix or can we fix it ourself? I have gone through our manual and haven't found a way to change that.
We have a NorStar M7208 Corded phone as well and when we moved the phone to another room, the phone does not ring. Thanks to anyone who can help us out.
It's RINGING now! I followed the Set Programming instruction in our manual. It's in Configuration 3-21. It's a very old old Operator guide. I am trying to find it online. In the mean time you can use the M7208 Phone Adminitration Overlay over the keys and program your phone by pressing Feature **266344 Here is a link to the overlay Good Luck.
Hard to answer because your problem description does not match the part. Nortel Meridian M7208 Corded Phone is a digital phone which works off a phone system.Also note that the carrier controls the rollover, not the phone or its system.
Once you have more/proper details maybe you can be helped.
You can use the do not disturb function on your set. When used it will stop all ringing on your set(both line ring and intercom ring). To turn on DND, press feature 85, to turn the DND back off press feature #85.
Incoming line ring settings are in the config menu under:
2nd option - Line access
enter extension number
2nd option - Ringing
Ringing then can be toggled on or off for each line assigned to that extension.
Mark
If you have call log set up you can access the log log by pressing feature 812. To program that feature as a one touch button press feature *3, press the button you what to be call log and enter feature 812
Yes, press Feature 4, then enter the extension of the line you wish to forward the ring to. You can also go into the phone configuration to forward after a set # of rings. To ring another extension at set times you will need admin access.
we moved one as well and now it does not ring i welcome an answer as well
What kind of Nortel system do you have?
