You may find this is impossible to do---the receiver if the set has buttons on front will be located there--if on same tiny circuit board as buttons you will have to TRY to find a replacement board--Good luck as this brand often NO parts are available.
While all IR receivers are similar they have different values and mountings.
I will presume you had the remote itself TESTED which will rule it in or out.
Ir receivers sometimes show no function unless remote is right up very close are bad---they also of course can fail where there is not any responses shown.
SOURCE: where can i buy a power supply for olevia lt37hvs
I have a power supply if you are still looking.
