Kitchen Appliances - Others Logo
Mrs M Atchison Posted on Apr 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My russel hobbs jug kettle is leaking very badly and it's not 2 years old yet
Just got up and realised the water was pouring out of the kettle. As I always buy Russel Hobbs products (Slow Cooker /Microwave /Toaster/Deep Fat Fryer) I am now worried they will all fail as the kettle is not 2 yeras old
mike cooper
Level 3:
  • Master 884 Answers
  • Posted on Apr 26, 2012
mike cooper
Master
Level 3:
Answers
884
Questions
Helped
405288
Points
1991
Why would anything else fail because the kettle seal has gone? They are generally ok aren't they?
1 Related Answer
richroth
Richard Roth
  • 9472 Answers
  • Posted on Sep 20, 2011
SOURCE: I have a Russel Hobbs
You will need to replace the heating element on the kettle. Here is a link to order the part.
Can anyone tell me where I can obtain a Switch Assembly for a Russell Hobbs Kettle model 3100/1/2
It appears that most parts are obsolete. You may have to just grow flowers in it as a keepsake.
https://www.google.com/search?q=Russell+Hobbs+Kettle+model+3100%2F1%2F2+parts
This was sooo promising
Russell Hobbs Obsolete Switch Assy Stat 3100/1/2 Kettle
BuySpares https://www.buyspares.com > kettle > product > shop=...
Buy Russell Hobbs Obsolete Switch Assy Stat 3100/1/2 Kettle online from BuySpares. Specialist supplier of Russell Hobbs Kettle Spares, Parts & Accessories.
tip
Leaks
I have had two Russell Hobbs electric jugs in the last several years. Both eventually leaked at the spout seams. Not good enough !!! In my opinion something is wrong with the workmanship or design.
1helpful
RUSSELL HOBBS 18941 KETTLE has slow leak from the bottom of kettle.
They are pretty much a disposable item when they fail. You could try repairing with epoxy putty. Some bases can be screwed a bit tighter.
https://www.google.com/search?q=KETTLE+MOD+18941
Manual
RUSSELL HOBBS 18941
and regarding kettle leaks
https://www.google.com/search?q=KETTLE+MOD+18941+leak+at+base
How to enter code
instructions - Russell Hobbs
uk.russellhobbs.com/pdf/14590_stylis_black_kettle.pdf
2 Don't put the kettle, stand, cable, or plug in liquid. ... 4 Don't open the lid while the water is heating. 5 Don't ... 8 Put the kettle on the stand - take care not to spill. .... To avoid environmental and health problems due to hazardous substances in electricaland electronic goods, appliances marked with this symbol mustn't be.Missing: code
Kettles - Russell Hobbs
en.russellhobbs.com > Our Products
Over the decades, Russell Hobbs has been at the forefront of quenching our national thirst for hot beverages with fast, easy to use, great looking electric kettles.Missing: open ‎question ‎enter ‎code
Russell Hobbs KE9000S Electric Kettle, Stainless Steel
www.amazon.com/Russell-Hobbs...Electric.../B00A15...
Amazon.com, Inc.Amazon.com: Russell Hobbs KE9000S Electric Kettle, Stainless Steel: Electric ...
Russell hobbs kettle base won't turn on
Just pulled apart a Russell Hobbs Whisper Model 3090 cordless kettle which i have been using every day for a few years.
It was intermittent turning on.
I fixed that problem by bending one of the switch contacts on the inside just a little as it had burned away slightly and was only making contact sometimes.
When I put the bottom back on and tested it I noticed that the water had an electrical smell which was strange as I had never noticed it before.
I then pulled it apart again and noticed that one of the main wires from the switch to the element had the insulation melting so I replaced that wire and now there is no smell in the water.
To confirm the smell I held the old wire and insulation on a flame and that is definitely what the smell was. The smell was travelling UP the tube which takes steam down to the bimetallic strip to turn the kettle off and was contaminating the water in the kettle.
3helpful
2answers
Leaking jug
A common cause is the calcium, or some other minerals in the water eventually ate through the bottom of the tank. You will need a new tank, or better... A new kettle.
Jerry G.
I have a Russell Hobbs kettle which is now leaking. Can it be repaired. It is several years old but still works well.
The coils of Russel Hobbs outrun the shell jar for sure as the corrosion in the kettle would have caused the leak.
The best can be to get the kettle welded with metal, use gas welding to mend up the leak and use a good grinding tool to polish off the suface.
Wash and clean/scrub well to remove all flux /dirt before you use it.
Boil water three times to discard before you use it.
You can continue to use the Hobbs.
20helpful
I have a Russell Hobbs Steam Generator iron - less than two years old. It has started to leak water - not really sure where it's coming from - it just pours out and eventually fuses the plug.
My Russel Hobbs Steamglide iron has stopped pumping steam , iron itself heats up but no steam...has the pump gone and can it be reapired
Oct 08, 2009 • Irons
Russell hobbs wisper quiet kettle
If it leaks now, it will in 2 weeks.....take it back.
Top Kitchen Appliances - Others Experts
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
