We bought the Graco Trekko about 2 weeks ago and from the very start the front wheel starts shaking horribly when running. I have to slow down to a walk to get it to stop and then speed up again, but the wheel starts shaking pretty quickly again after that. Any suggestions? I've tried to use some of the suggestions for other stroller brands but it they are just not made the same.
I am assuming you have lubed the wheel with a silicone based spray lube.
Is it wobbling with the wheel in the locked position? Th only reason a wheel can wobble is if the axle and the actual wheel have too much play. A thin shim washer may tighten the axle to wheel spacing. Most hardwar stores will have thin washers. Give it a try. Your manual made no reference to wheel maintanance so if you purchased it new I would call Graco and complain. If used, try to eliminate the problem. If you need it here is your manual.
Graco Trekko Manual
SOURCE: My Graco Infant car seat STINKS and is brand new!
have you tried washing the actual seat (not cover) and base if not take the cover off and use bleach (on plastic parts not cover) and get in the groves/ Hallows on the seat & base
SOURCE: graco car seat
cant help you you need to take the seat to a dealer to show you how for safty reasons
SOURCE: I have a stroller graco model 7240mkL2 and no
go to gracobaby.com and get a free manual. u will need the model and serial no. there are button straps on the sides that that u can adjust.
SOURCE: install graco snugride to a graco stroller
Fitting your Graco Snug Ride infant seat into a Graco stroller is usually easy to do -- the exact instructions just depend on which stroller you have. Typically, all you have to do is fold the stroller's canopy back, recline the seat (if it reclines), and snap the car seat in (backwards -- facing the rear of the stroller). You can hear it lock in place when it's in correctly. Your stroller's manual will have specific instructions, and if you don't have the manual you can find it online.
Which Graco stroller do you have?
Also many of the "Joging" type strollers have an adjustable nut under the front plastic cover. Remove the cover and tighten the nut, just a little. Test the stroller to see if the wobble is gone. Been there, done it!
Sorry, "Jogging"!
