Hi please can somebody help me. i have a samsung tv but i ahve currently a dvd recorder connected to it. i'd like to connect the home cinema system that came with it but don know how to as i dont have the instructions. i'd like to keep and use both dvd players....as i cant connect the speakers etc to my dvd recorder...confused i am!
SOURCE: not getting sorround sound from my tv
Sounds as though you need to connect the TV via either phono or optical/digital lead (depending on TV) to the AUX input on your reciver. This will then alow you to hear the TV through the system
SOURCE: ht-x30 samsung cinema system display unknown disc
TThe player does not play this type of dvd disk! only pre-recorded movies and CDs Try hooking Up a player that plays DVD+ and DVD- disks!Hope I was of help!
(please use The ratings to keep this site free!)
SOURCE: SAMSUNG HT X30 SHUTS DOWN WITH" PROTECTION"
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be with your output drivers. Please check for short on the outputs fitted for both the channels. Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise which can be a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board. Maybe the protect circuit by itself is shutting off due to a faulty bias or there is a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the amplifier comes out of the protect mode then check for short on the speakers.
