How can I tell if the hinges on the stove door is broken?
SOURCE: oven door does not close
Remove the side panel and you will have an access to it. Good luck !!
I had the same problem. The first time the Tech. came out, put a new hinge in and it held until Nov. 07. ( 8 months ). Then the left hinge brakes when I opend the door and it crashes to the floor. Bending the right hinge and the metal doorliner. Jan.7,08 everything was fixed. On 1/11 after no more then 10 openings & closings the hinge broke again. This time I heard the crack of the braking metal after opening the door 2 inches. It now sits in my kitchen propped-up with a stick, waiting for the repairman. I am sorry I have no solution , but there must be a problem with the hinges. I forgot to tell you that it started with a door that did not close, like yours.
Ingrid
SOURCE: Hotpoint BS 21 fan oven Broken door hinge
Pull the door down as far as it will go, and at the lower end of the hinges, there you should see what looks like 2 round discs, with a step cut out, rotate the discs with a scewdriver as far as they will go,then close the door and pull it towards you, the door should then pull off.
Replace both hinges, not just the one ,or it will close unevenly.
Slot the hinges back into the hinge slots, pull the door down, rotate the disc back to their original setting, and that should be it.
Plz rate this solution. Thanks.
SOURCE: Oven door hinge detached from the oven
Pull the door completely off and re-insert the door on the hinge supports.
SOURCE: STOVES 600 oven door wont shut properly
open the door about 30 degrees, lift straight up to release the hinges, this will allow you to remove the door.
you will be able to assess the hinges from there.
most likely the hinges are just out of alignment
