Is there a new 10 digit code for replacing filter on robinair 34788?i try the old two codes that Mr Hasan Khan Amran posted but fail please post another code ...God bless you
Please be informed that, one code can be use only one time! However now
i will give one more new code: 6FAAC95001. Apply it now and solve the problem!
Don't forget to vote for it, if you wish to get help in future. Good luck....
Testimonial: "it works perfect !!!! Thank you very much... My question is why the new filter code doesnt work but your code is always accepted.. ? can you recommend or suggest where to get filter drier with code next time we will need it? "
Please contact on this number for detail: +965 66880748
Try with this code EC1D4F1C03. But you must change filter as well. If not changing filter then after sometimes it will damage compressor.
How you always get a perfect cheat code?? ;-)
rohit sethi, what do you mean by "Perfect cheat code"? Just for your info. I have 13 years carrier of Specialized Automotive equipment and I am the best awarded technician in the meddle east by Robinair. so please don't make any silly comment. I am here just to help people not to doing any stupidity!
The filter lock out was mandated by the EPA http://www.epa.gov/cppd/mac/JIM%20RESUTEK.ppt using a generic code to bypass the filter change is illegal. if you have a filter an the code is not working call tech support @ 800-822-5561 and they will fix the code. If you have a filter that does not have a code return it to the store to get one that does
I have a rhs980. with get a code?
SOURCE: I have robin air 34788.
Try with this code-FD32C46B01. I'm sure this will work! Good luck & vote for my solution
SOURCE: How do you perform a manual reset on a 34788 cool
There is no way to reset without filter code. This machine ( Model-34788) will not accept even new filter code,if filter from old verson (manufacture before the machine). However try with this code-FD32C46B01. I'm sure this will work! Good luck & vote for my solution.
If that codes Amran gave dont work then you used them before and need to get a new filter, the new filters have good codes on them, buy a new filter
amran should not even be giving codes out !
FEBCFCBE01 and EEC43D0707
Ocd1360504
Just used code: 0CD1360504
and it worked!
Thanks so much!!!
