Hi i want ur help i have htc g1 android 1.1 and i want to update it plzz helppp
I never had that problem with mine, however i have heard of that before.....try clearing out your content cache from the browser settings to see if that helps. t-mobile wont really be able to do much more then that or resetting your device.....
to clear out your cache, go to:
MENU > SETTINGS > APPLICATIONS > MANAGE APPLICATIONS
once your here, select BROWSER then select CLEAR DATA. if that doesnt help any, try to power off your handset and turn it back on after a few seconds.....
worse case scenario, you will need to reset the handset....if you do this, you will need to log in again with the username and password with the google account you signed in with when you first bought the phone....
to reset the device, go to MENU > SETTINGS > SD CARD AND PHONE STORAGE > FACTORY DATA RESET > RESET PHONE > ERASE EVERYTHING
good luck! let me know if that works! :)
Call t-mobile. they need to reset your data access.
SOURCE: my gmail app now longer works on phone. I get
update the software to your cell handset, or simply manually go to mail.goggle.com
SOURCE: AOL emails show Connection Error - Google Android phone (Moment)
Reinstall your AOL software , it is not automatically detecting your connection settings
SOURCE: Hi I have Android phone G1-Dream.
You may need to wipe the factory setting. To do so, Turn Off
the cellphone, now keep on holding the Home button and turn on the
cellphone. It go to the recovery console, now select WIPE or press the
short keys mentioned over there and restart cellphone.
Note: You will not loose any data but you may need to resign to google and also may need to install some application.
Thanks and regards,
Anil.B.R
