SOURCE: Vertical Black Line
HI,
First thing to do is the reset and the whacking test. I give this a 50/50 chance of clearing it up.
ONE: Disconnect the power cord for 4 hours. Then when you power it back
up the internal soft codes will automatically reset to factory defaults.
TWO: The whacking test is to just bang or smack the set with your hand
on the back, side, top, etc., to see if there are loose connections or
cold solder joints inside that are acting up. If so, the banging should
knock them back to normal and the set should restore. You might have
to use some creative banging and some have had to put a book or
magazine under one corner to torque the chassis enough to get it to
work reliably.
If these two procedures do nothing then:
The manual always knows the best.Go through the manual carefully and u will find the solution to ur problem..
Goodluck and Kind Regards
Please Don't forget to rate me as fixya..
SOURCE: solid vertical line on JVC 42WV74
umm trying using it more, i had the same exact problem and we started using it more and more it has recently gone away.Check the wires as well (plug them out and back in)
SOURCE: JVC PD-42DX6BJ plasma 42 inch black horizontal lines over the pic
Here's a link to order the original the JVC upper Y-buffer board and lower Y-buffer board for this model from a major parts distributor if needed:
JVC "PD-42DX6" Replacement Part Upper Y - Buffer Board (LJ41-02760A)
JVC "PD-42DX6" Replacement Part Lower Y - Buffer Board (LJ41-02761A)
Based on the symptoms: It is possible that the Y-buffers are faulty, which may require the replacement of the Y-sus board as well. You may want to get a local technician to diagnose the unit and provide a second opinion.
SOURCE: Sound stays on, but no picture- goes black and stays that way.
This unit should still be under warranty and should be taken in for warranty service. Any attempt to access the interior will void the warranty. It is important that a complete description of the problem like you entered here be taken along when you bring the set in for service. This will insure that the servicer be able to reproduce the problem and resolve it.
From your description (and as a servicer), I would be looking for a component that is heat sensitive. These types of problems are fairly easy to locate and resolve.
Please take this in for warranty service and update this when you find out the details.
Thanks,
Dan
