Microsoft Windows XP Professional x64 Edition for PC Logo
Anonymous Posted on Apr 05, 2012
Favourites is missing
Fawourites is missing
IMDante
Level 2:
Scholar:
  • Expert 141 Answers
  • Posted on Nov 25, 2013
IMDante
Expert
Level 2:
Scholar:
Answers
141
Questions
0
Helped
31264
Points
249
Right click on the Tool Bar (any where below the URL window) and find Favorites on the popup-menu and select it/click on it and it will automatically check Favorites. Once that's done Favorites will show on your Tool Bar.
1helpful
I need a users manual for navmii gps navigation software For Windows
https://www.microsoft.com/en-us/store/p/navmii/9nblggh10k57 = software.
Navmii used to have an old manual at http://www.navmii.net/bin/Navfree_UserGuide_v1.0.1.pdf
The link no longer works.
Here are some basics:
Basic Navfree Help
Navigation is easiest if locations are added to Favourites before navigating. To check a location before adding it to Favourites, or find a location near another location:
Tap Menu icon at bottom right of map screen. Tap Navigate on Main Menu. Tap Address or Google.
Type name to find. Done. Tap down-arrow beside item . Tap Show on map.
Check it is the correct place. If so tap down-arrow and Add to Favourites.
Or drag map to required location. Tap on map. Select Add to Favourites. Change name if required.
To enter a route from A to B, when A is not the current GPS location.
Need to disable GPS in Android Settings - Location.
Easiest if A and B are entered into Favourites. Use Google Search or Address to find names and descriptions, then Add to Favorites.
Then tap Navigate on Main Menu. Tap Favourites and select A.
Tap box with Favorites name in it, and select 'Route from Here'.
Tap Menu icon at bottom right of screen. Tap Navigate. Tap Favourites.
Tap 'Route here'. Tap 'Selected' (not Gps).
Tap 'My Route' to see Route on map.
To clear route: From Main Menu, tap Clear Route.
Cant edit or delete (sometimes) Favourites. Use Jota app . See forums.
Still looking for manual, there blog is very helpful which is the link above.
Helpful links,
https://groups.google.com/a/navmii.com/forum/#!forum/android-app
https://groups.google.com/a/navmii.com/forum/#!topicsearch/user$20manual/android-app/CibF963hA5I
1helpful
How to put a desktop icon for FixYa on desktop
do you want to make a shortcut ?
if you right click on the opened fixya page right click select add to favourites it will be added to the favourites for short cut click on the faourites you will see fixya on the drop down list
if you dont a favourites tab right click in the top toolbar select the menu bar which will add File Edit View Favorites Tools and Help
2helpful
How do I delete items from recently found? How do
When you want to add a place to your favourites
  • Press WHERE TO
  • Enter the address
  • Instead of pressing GO press SAVE at the bottom of the screen or press VIEW MAP and then SAVE
It will be saved to your favourites folder and the keyboard will come up for you to give it a name.
You don't delete items from recently found. A certain number of items are kept there and overwritten as new ones replace older ones.
How to write adress to Favorite in GPS Garmin nuvi 265 WT
  1. Press WHERE TO and type in the address
  2. Instead of pressing GO press SAVE which will be at the bottom of the screen
This will save the address to Favourites and give you an optoin to give it a name.
If you're at an address and you want to add it to favourites press the car on the map screen.
You'll get a message asking do you want to save your current location. Select YES and it will be saved to favourites.
How do I delete my favorites?
To delete all favourites:
With the satnav turned off press the bottom right corner of the screen with your finger and while pressing it turn it on.
Keep your finger pressing until a pop up message appears
Press yes and all user data will be erased. This will reset all original settings.
If you only want to delete some favourites:
Press Where to, press Favourites, select one to delete, press Edit, and press Delete.
This way you can delete them one at a time.
3helpful
I have a Garmin Nuvi 205W and have saved a number of places as favourites. However, when I want to share the location with friends by giving them the map coordinates of these places I cannot find how to...
To view the coordinates of a saved location on your nuvi
  1. Touch Tools (wrench icon)
  2. Touch Settings
  3. Touch System
  4. Turn ON the GPS Simulator
  5. Touch OK
  6. Hold Back to return to the main menu
  7. Touch Where To?
  8. Touch Favorites
  9. Select a favorite location
  10. Touch Show Map
  11. Touch Set Location
  12. Hold Back to return to the main menu
  13. Touch Tools1
  14. Select Where Am I
Here you will see the coordinates for the saved location.
1. For nuvi 200 series units that do not have the Where Am I feature, skip the above steps 13-14. The coordinates can be found by pressing the vehicle icon on the View Map page.
Instructions on Backing up and restoring Favourites can be found at
http://www.garmin.com/garmin/cms/cache/offonce/us/support/searchsupport;jsessionid=72CF55C22FEF1BA5AA08FFCAC89B9E59
Using favourite-tabs will close IE8b
check if you got IE8 Beta latest version.(I'm using Beta 2)
download and install latest version
Export your favourites
Delete all your favourites
Check if issue replicate with empty folder.
Restore your favourites by small batch.
Check if any set of links triggers the problem.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
