I have a Twin Star fireplace model 23EF003SRA got power lights but no fan heat and flame. What is possible solution to fix this problem??
SOURCE: Problem with HomePride model TE555 fireplace heater
I hav ethe same heater but my coil does not get hot. I am trying to find a replacement part for it but no luck. I called the number (905-847-2643) of the company but no call back.
SOURCE: electric fireplace does not heat
I have a cheap electric fireplace bought in SuperCentre store-heater no longer works. It says its a one piece system. Can these heaters be replaced or repaired(probably made in China) or am i better off scrapping it and buying a new one?
SOURCE: I have a pyromaster electric fireplace model HEF
Unplug the motor wire connector and jump it with a 9V. battery. If the motor spins it's good. Chances are the FLAME SPEED CONTOL (Part Number 10001589) circuit board is bad. I had to replace mine. It's at the bottom of the fireplace behind the contols panel.
Good Luck
Perry Gibbs
SOURCE: The switch that turns on
I'm sorry, but we don't sell any parts or appliances here on FixYa. We simply provide information on how troubleshoot and/or repair many things. With that said, I can tell you, from what you described, you need more than just and ON/OFF Switch, if in fact, it "burned out". Something else electrically is wrong with your electric fireplace-heater to cause that.
Unfortunately, you failed to mention the Model Number of your Charm Glow Fireplace, so I can't steer you, to where you may be able to find a replacement switch. If you can provide that information, I may be able to help you.
