Hey there! Nice receiver :0)
Sorry about your troubles. I've been where you are with an Rx-V2600. Would turn on and after a few seconds click off. I thought maybe it was bad wiring but even completely disconnected it would still do it.
I took it to a shop and I was told it was a bad channel. Luckily I mentioned I had a Denon receiver that had stopped working and he said he would take that as payment.
He fixed the Yamaha and it's been working for years.
If you search the internet you should find a local authorized Yamaha repair center. I would take it there. They marked charge like a $30-$50 fee to look at it but usually they apply that towards the repair.
SOURCE: Yamaha RX-V595A tuns off automatically
This was happening to mine also, all of a sudden. This solution came from the owners manual. Sure enough, the impedance selector was stuck in the middle , between 4 and 8 ohms....I also, made sure the speaker wires were not touching each other at the splice. Problem fixed.
B
The unit fails to turn on when
STANDBY/ON is pressed, or set in
the standby mode suddenly soon
after the power has been turned on.
The power cord is not plugged in or the
plug is not completely inserted.
The IMPEDANCE SELECTOR switch
on the rear panel is not fully set to the
upper or lower end.
Firmly plug in the power cord.
Set the switch fully to the upper or
lower end when the unit is in the
standby mode.
SOURCE: Yamaha RX-V595a receiver shuts off 2 seconds after its powered on
The first thing called out is the impedance switch on the back is not fully in one or the other position. Cycle the switch back and forth to make sure it will 'read' each setting, then turn it on.
Also make sure you if you have anything connected to its convenience outlets that they are not drawing more current than is allowed.
Did you buy it used or new?
