If I buy a XD picture card adaptor
SOURCE: Fuji FinePix S5000 stopped taking pictures. Told need sensor?//
CCD failed, replacement needed.
SOURCE: initializing of xD-Picture card
The S3000 has a 512MB limit according to Fuji. Ther is also no firmware upgrade to address this issue. However I loaded a 1GB Olympus M type card into th S3000, which was pre-fornatted and worked straight away. After putting the card into the reader in my laptop, and then returning to the camera, the camera identified the card as not initialized. I tried to format the card in the camera but this didn't work.
To fix this I connected the camera to the computer using the USB cable located the camera card via My Computer, left clicked on and did a quick format in FAT (FAT16). After this the camera read the card and indicated 1305 frames available at 3M.
SOURCE: on screen file no. full and I can not take pictures anymore
The solution is: 1. go to set 2. go to frame no. and reset. You can make pictures again.
SOURCE: Fugi S5000 2gb xd M+ Computer says it's not formated
Yes, it would appear that you solved your own problem. The Fuji S5000 apparently only takes the max of 512 mb card. I own a newer Fuji S700 and it works fine with a 2 gb SD card, but I haven't tried anything bigger. Your best bet is to see if you can exchange those 2 gig cards for 512 mb cards at the store where you purchased them, and then try the 512's to see if your pc will read the pics. Explain to the store what the problem is and they should allow you to make the exchange.
