Dell Inspiron E1705 Notebook Logo
larry liverett Posted on Nov 09, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dell latitude D600 battery charge light flashing
My Dell laptop's battery used to work properly and charge and show a green light flashing while charging. Now I can't get the battery to charge and when it is plugged in I am seeing the charge light flash orange quickly 4 times, followed 1 longer green light flash.
The computer appears to work fine while plugged, but won't work when it is not "plugged in". battery light flashes orange when fully charged
  • 3 more comments
  • Cuttypan Jan 08, 2009
    Dell Inspiron 5160 laptop Light is flashing orange
  • Anonymous Apr 07, 2009
    Same problem. 4 orange flashes (quick) and then one long green one. Also when testing the battery, I have three LED lights flashing and then all 5 at the end. What does this mean?
  • Anonymous Apr 16, 2009
    i have three orange flashes in quick succession followed by a longer green steady light for a second then blank and the sequence repeats on my dell inspiron 6000
  • Anonymous Mar 17, 2014
    the notebook will not turn on. It has been working fine until today after full charge. Thank You.
  • Anonymous Mar 18, 2014
    Slate works only while plugged in charging and windows battery remaining shows 0%(plugged in charging)
Walter H Boehm
Level 3:
  • Dell Master 998 Answers
  • Posted on Nov 09, 2008
Walter H Boehm
Dell Master
Level 3:
Answers
998
Questions
0
Helped
341004
Points
2289
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
1 Related Answer
Anonymous
  • 2559 Answers
  • Posted on May 29, 2009
SOURCE: Dell latitude D600 battery charge light flashing
The 4 orange flashes mean the battery is defective.
My Dell laptop's battery charging circuit faulty.
try to remove your batt and check if laptop works fine with ac adapter alone.
if yes then put batt in then check how much charge you have if you have about 10% then update the bios immediately.
if fails then have the batt replaced.
1helpful
Dell latitude d600 will not turn on / power on
it means not charging the battery pack, did you check the dc jack connector, or the.
charger check it if working properly, if the same problem open the laptop then check the baord
thanks
Go to support.dell.com and download the latest bios firmware to update it. If it still does not work then most likely it is already a hardware issue so you need to contact dell support for the hardware issue.
4helpful
4answers
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
2answers
Dell latitude d600 blinking battery light
I would say its defective. Bring it back to where you bought it and show them. Bring your laptop charger also so you can show them it in action. Hope this helped.
Dell battery problem
Hi Roy,
Dell, apparently have had some problems with their batteries, as they called back some, including yours.
Goto Dells homepage here and goto -> a bit down this page -> Step 1: Is your battery model affected?
Hope your battery is among these, as you will be able to get a new one.
regards
/Teis
3answers
my suggestion is that you allow the batteries to fully recharge(which only happens when the computer is fully off, when the battery is deep discharged.
that will take around 6 to 10 hours each..
6helpful
2answers
Orange and green light flash
The flashing battery light is an indication that the system is attempting to charge the battery. The orange light indicates a problem charging one of the battery cells. This usually means that the battery either needs to be recalibrated or replaced. To recalibrate the battery just use the system until the battery is dead, then recharge and repeat the process twice, after which time the battery should be recalibrated. If this doesn’t fix the flashing orange light then the battery may need to be replaced.
hope this helps
Dell Latitude D600 new battery won,t charge
the charger in the laptop is not functioning. pc will need repaired
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
