My phone says sim card rejected. It is the sim card that came with the phone. Good evening sir, my mobile create a problem in which it display on the screen is sim card rejected. sir help me how to solve the problem of sim card rejected.
SOURCE: sim card rejected
this happen if there is some problem in the sim card holder port ....
there
will be loose contact inside the sim card holder is not touching the
circuit board inside due to this your sim card is getting rejected ...
as
you have told that the phone is a brand new one so i am sure that you
will be having the warranty so just make use of it by contact the
dealer with whom you have purchased or contacting the company customer
care number to get more information about how to make use of your
warranty ......
if you dont have the warranty then you must open the handset
and
just remove the circuit board & sim card holder and insert it again
so that the sim card holder touches the circuit board correctly ...
after this refit the phone then surely your sim will be accepted ....
it is better to use of warranty if you have ......
this is a simple problem if you dont have the warranty also you can only fix it ..
if
you just open the handset & set that sim card holder to touch the
circuit board that s enough everything will be done and works fine ...
if you are afraid of opening then you must just contact the technician ...
it is just a matter of very little bucks if you contact him also ...
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
hi
you can call the company from another phone and fix the problem by giving them the PUK number.
i hope this will work
there will be loose contact inside the sim card holder is not touching the circuit board inside due to this your sim card is getting rejected ...
as you have told that the phone is a brand new one so i am sure that you will be having the warranty so just make use of it by contact the dealer with whom you have purchased or contacting the company customer care number to get more information about how to make use of your warranty ......
and just remove the circuit board & sim card holder and insert it again so that the sim card holder touches the circuit board correctly ...
if you just open the handset & set that sim card holder to touch the circuit board that s enough everything will be done and works fine ...
thank you
bye
rate my solution
i got the same problem -.-
I also got same problem
i also got the sae prblm
i also got the same problem
