Lands Phones Logo
Anonymous Posted on Mar 22, 2012
Turn on voicemail indicator on my vtech - Lands Phones
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Lands Phones Master 102,366 Answers
  • Posted on Mar 22, 2012
Lands Phones Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10444598
Points
622693
On most VTech phones the voicemail indicator turns on when someone leaves a message on the voicemail system offered by your phone company. Many phone companies have such a system, which takes messages when your phone is busy. You'll have to contact your phone company for instructions on accessing their voicemail system.
I have a VTech 6929 Phone system. I have tried everything in the manual instructions, but I cannot set up my mail box. I had it previously, and somehow it is gone. Can you help?
Question edited for clarity.
This phone system has two features.
Answerphone system which records messages to the unit.
and
Voice Mail System which is an extended (often paid) service from your telephone provider.
Sometimes a glitch at the Telcom will remove your Voice Mail. You will need to phone their customer service number and ask why they stopped the service you previously enjoyed? They will be able to put it back in place.
Page 32 refers
https://cdn-media.vtechphones.com/products/CS/CS6929/CS6929-X_WEBCIB_V3_20160224.pdf
Retrieve voicemail from telephone service Voicemail is a feature available from most telephone service providers. It may be included with your telephone service, or may be optional. Fees may apply.
Retrieve voicemail When you received a voicemail, the handset displays New voicemail and . To retrieve, you typically dial an access number provided by your telephone service provider, and then enter a security code. Contact your telephone service provider for instructions on how to configure the voicemail settings and listen to messages. NOTE After you have listened to all new voicemail messages, the indicators on the handset turn off automatically.
Set your voicemail number You can save your access number on each handset for easy access to your voicemail. After you saved the voicemail number, you can press and hold to retrieve voicemail. Press MENU when the handset is not in use. Press or to choose Settings, and then press SELECT. Press or to choose Voicemail #, and then press SELECT. Use the dialing keys to enter the voicemail number (up to 30 digits). Press SELECT to save. You hear a confirmation tone. • 1. 2. 3. 4. 5. 33
Turn off the new voicemail indicators If you have retrieved your voicemail while away from home, and the handset still displays the new voicemail indicators, use this feature to turn off the indicators. NOTE This feature turns off the indicators only, it does not delete your voicemail messages. Press MENU when the handset is not in use. Press or to choose Settings, and then press SELECT. Press or to choose Clr voicemail, and then press SELECT. You hear a confirmation tone.
How do you check your voicemail on a VTech cordless phone
The cordless phone pictured appears to be a VTech CS6114
and an Answering Machine System is not part of this phone.
** BUT ** an Answering Machine System is not the same
as "VoiceMail" anyway.
VoiceMail is an option offered by some (not all) telephone
service providers, and each of those who do offer the feature
employ specific procedures unique to themselves.
Check with your Telephone Service Provider to see if you
do have a VoiceMail service activated and how to go about
using it.
Per the CS6114 User Manual, the display indication shown,
"New VoiceMail", will be removed from the cordless phone
handset when you have accessed the providers' VoiceMail
system and played/cleared the messages.
If the alert display persists, it can be cleared from the handset
by the following (tested on my own cs6114 phone):
press [menu]
scroll to "Settings"
press [select]
scroll to "Clr voicemail"
press [select]
display reads "Reset VM Icon?"
press [select]
phone will (chirp)
press [off ] [off ]
How do I check voicemail
VoiceMail is not a function or feature of the VTech cordless
phones.
have or can get a VoiceMail service activated and how to
go about using it.
"New Voicemail" will be removed from the cordless phone
press [menu]
press [select]
press [select]
press [select]
phone will (chirp) press [off ] [off ]
Need to turn the voicemail indicator back on & get rid of beeping dial tone.
You apparently have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
I can;t listen to my voicemail from my vtec phone model cs6419-16.
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
The voicemail doesnt want to turn on
You may download a copy of the manual here. The answering system instructions begin on page 26.
How do i listen to voicemail on my vtech phone
The CS5113 isn't an answering machine. However, it works with the voicemail system offered by your telephone company. Please contact them for instructions on accessing their voicemail system.
Dect 6.0 will not take a message , but new voicemail indicator is on
Vtech Model 6042 Voicemail Indicator Light Does Not Work
How to set up a voice mail indicator on vtechcs6219-2
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
