found how to adjust valves: put on tdc. intake is .003 exaust.oo5. set screw in nut is the adjusting ,turn in or out to set. then tighten down to specs.found how to adjust valves: put on tdc. intake is .003 exaust.oo5. set screw in nut is the adjusting ,turn in or out to set. then tighten down to specs.
AnonymousJun 04, 2019
Wrong! As of 2014 the newer Manuals say Intake is .005, the Exhaust is .007 and you adjust the clearance with the 10mm rocker nut. Then holding the rocker nut in place with the 10mm wrench so it does not turn you then tighten the set screw to lock the setting in place. Cheers!
You can't post conmments that contain an email address.
you check the oil with the dipstick resting on the tube, not screwed in
then check your fuel supply as it might have water in it
then remove valve covers and see if you have a valve guide seal that has moved
