Can i get a dc charger or can i use a dc/ac converter to charge my unit?
SOURCE: travel pal will not charge
It is time to replace the batteries. Buy two, not just one. This scooter takes two 12 volt, 12 amp hour, sealed deep cycle batteries. If you replace just one, the charger will not charge them properly. Take off the seat (pull upward). Turn the scooter on its side. Remove the six screws (2 in front, 2 under the foot rest, and 2 in the back. Unsnap the old batteries (one at a time) and replace with new. Be sure to keep the wiring as is, so you keep the circuit in series (not in parellel). In fact, before you remove the old batteries, label the connections (A to A, B to B, etc.) so you reconnect just as they were. Total cost is about $200. Time to replace is about a half hour.
SOURCE: Travel Pro Scooter charging problem.
hi , sounds likek a charger problem but if you have tried another charger then check the charger plug connection where the charger plugs in,
Check the batteries are connected correctly.
Regards
GeWiz.
