2001 Hyundai Santa Fe Logo
natassja Posted on Mar 20, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2001 hyundai santa fe starts with one crank but won't go into drive or reverse, only goes into park and neutural what could be the problem? i have a 2001 hyundai santa fe 2.7 l v6 all wheel drive
Reynaldo Andico
Level 3:
  • Hyundai Master 2,431 Answers
  • Posted on Mar 20, 2012
Reynaldo Andico
Hyundai Master
Level 3:
Answers
2431
Questions
0
Helped
1236407
Points
7940
You do have drive and reverse,if you have park and neutral.It just the transmission cant transfer that power a new or rebuilt is the solution
My 2001 Hyundai Santa Fe cranks but won't start. Diagnostic tester reads, ' Err ' key not detected.. Key is in the ignition !! PLEASE HELP !!!
Engine cranks but won't start.What should I do. - YouTube
? 9:37
https://www.youtube.com/watch?v=jsQcLya1YLQ
Jan 24, 2014 - Uploaded by jimthecarguy
No Start Cranks Ok No Injection Pulse 2002 Hyundai Accent Easy Step By Step ... Jimmy, i strugle to start my trajet 2.5 v6 after installig new engine. ... type of hyundai accent 2002, the engine cranks, but It won't start, no spark, ...
My engine cranks but won't start what should I do - YouTube
? 9:37
https://www.youtube.com/watch?v=ecLmYPcWipo
Feb 11, 2014 - Uploaded by jimthecarguy
2002 Hyundai Accent No Start ,Cranks Ok Spark OK ,No Injection Pulse My car will not start what should
About 1,770 results (0.59 seconds) Search ResultsHyundai Santa Fe Electrical Problems - Edmunds.comforums.edmunds.com > Hyundai > Hyundai Santa FeMay 8, 2007 - 31 posts - ‎24 authorsLearn more about Hyundai Santa Fe at the Edmunds.com Car Forums! ... and whether it left an error code on the computer when I next take it to the shop. ... My Hundai Sante Fe 2002 has been having strange electrical issues ... It does not have a remote starter but does have an alarm and electonic key."No Start" Due to Drive Authorization's Failure to ... - RepairPalrepairpal.com > Problems > Mercedes-Benz > ML350In many cases, a new module and keys will be needed to correct this ... Chrysler, Dodge, FIAT, Ford, Geo, GMC, Honda, Hummer, Hyundai, Infiniti, Isuzu ... my 2005 mercedes benz ml350 would not start, it telling me star error. ... Says key not detected, I changed batteries. .... Mercedes-Benz Repair in Santa Fe Springs, CA.Missing: 2001 ‎errHow do you start the car with the key in the console slot ...www.hyundai-forums.com/.../149516-how-do-you-start-car-key-console...Oct 5, 2012 - 10 posts - ‎7 authorsI had an incident yesterday where the car did not seem to detect my key. When I pushed the ... The manual says if the battery is weak to insert the smart key into the center console slot to start the car. Well ... 2013 Sonata Limited 2.4L 2011 Santa FeGLS 2.4L 2001 Santa Fe GLS 2.7L .... HTML code is Off.Missing: error ‎errdb:: 4.99::Blue screen Error FE 9p
2answers
What would be wrong when my car has gas, but no spark?
2001 Sante Fe Won't Start, Cranks But No Spark. - Hyundai Forums ...
www.hyundai-forums.com/...santa-fe/112601-2001-sante-fe-won-t-start-...
Jul 23, 2010 - 10 posts - ‎3 authors I have a 2001 Hyundai Sante Fe that died on me while driving down my street. ... Thecar has many other unrelated problems and I am not sure I want to ... may be causing my two cylinder no spark and alleged fuel problem? 2006 Santa Fe 2.4 Engine swap-no spark
Sep 24, 2012
No Start 2.4L Engine 2004 Manual
Nov 26, 2011
Good Crank/Have Fuel pressure/NO IGNITION
Oct 9, 2011
Car Cranks But Will Not Start
Jan 16, 2008
More results from www.hyundai-forums.com
? 9:37
No Start Cranks Ok No Injection Pulse 2002 Hyundai Accent Easy Step By Step ... and car cut off, but would not restart. it sounds like it is starving for fuel. ... hi nice video man . i have no sparkno fuel .u think its the main? it was ...
Trans won't shift only manually 6 cyl also won't go over 40 mph. 2002 hyundai santa fe
this sounds like a timing belt problem.
http://www.youtube.com/watch?v=nyB6syDyP0o
This is what could happen if not replaced.
My 2001 hyundai santa fe engine revs up and down constantly. It doesn't matter if its in park or while driving. The check engine light has always come on and off. I've had that checked several
Do you have cruise control,see if that cable somehow is giving slack,This is a problem with Hyundai where the cable affects TPS plausibility,There was a TSB bulletin by Hyundai Engine RPM fluctuation - cruise control cable adjustment procedure
2001 hyundai santa fe sputters and won't go past 5 miles an hour. At 3000 rpms in park it shuts down. what can I do to solve this problem, thanx
It sounds like the exhaust system is clogged. Try looking under your vehicle with a flashlight and look for bends/kinks in the exhaust pipes. I had a similar problem with my car, when the catalytic converter broke apart, and clogged the exhaust. i could barely reach 20km/hr, and the engine would shut off at 2500 rpm. Replacing the catalytic converter fixed my problem.
Matt
3helpful
4answers
2001 Hyundai Santa Fe - Engine Code P1602, stuck in gear
Im having the same problem with my 02 Santa Fe. How do i go about fixing this problem? And is it costly? Please help
2001 Hyundai Santa Fe the engine crank put it dosent start some
the problem is crank angel sensor and it took me 4 hours to change it
Top Hyundai Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
