I got a new xbox 360 slim 250 GB, I play it on old TV and it lags Offline! First i thought it was normal, but a few days latter single player lag is so bad that almost every game is unplayable. I searched on internet and i discovered that a lot of people have the same problem. Is there a way i can fix it by my self? Sorry for my bad english.
Its called input lag which is caused by your tv look up response times reviews for that particular model of tv and MS speeds for that tv if that is not the issue the xbox could be faulty or your hdmi cord could be bad
Hi dinobots,
Do you use Wi-Fi or an ethernet cable? If you are experiencing severe lag, it could be a problem with your actual internet connection and not necessarily your XBox 360.
I would purchase an ethernet cable (they run about $10 over here in the states) and try that out before anything else
It's Offline lag, not Online! there are games lagging offline, in cutscenes, explotions when a lot of stuff going on on screen. Games are unenjoyable. and this lag is almost in every game.
Hi dinobots,
I have never heard of offline lag but totally understand how that would be unenjoyable for you.
Are you still able to return the system to the store you purchased it from? That seems like the best solution for this issue, because I have never heard of offline lag that was this bad before.
Hope that helps!
SOURCE: Xbox 360 - Oblivion IV - loading probs
Next time the game is loading, try clearing out the cache. You can do this by holding down the A button while the game loads. When you see the Oblivion title screen come up, your cache should be cleared. This may clear up your issue. If that doesn't do it for you, you can try to clear the cache out another way. There are many websites that can assist you with that. When in google, search for: Clear XBOX 360 cache. Hope this helps you.
There is a perfect way to play your old XBOX games in Xbox 360 games.
you are in luck that you bought ARCADE,if you ve core without harddisk yo cannot play,
so the solution is
you need the FLASH UPDATE as above.
you'll need the hard disc drive accessory plugged into your Xbox 360 to play old Xbox games
if its there we can simply play it.
need to follow these
sign in to Xbox Live. Where do you find the update?
To get the update, all you need is to have your 360 connectedonline and logged into Live. Insert an original Xbox game into the360's disc drive, close it, and the update should begin automatically.Being on Xbox Live is the most hassle-free way to make sure you canplay Xbox 1 games, as the system should automatically update each timesupport for new games come out.
If you are not online with Live. How do you get the update?
You have two options - either order an update disc from Xbox.com(which will be sent by mail and incur a small fee) or, if you haveaccess to an Internet connection and a CD burner, you can download theupdate yourself.To download the update yourself, visit this Xbox support page.The download itself is roughly 2.5MB. Simply unzip the downloaded file,burn it onto a blank CD or DVD (it must be the only file on the disc),and insert it into your 360. The process should begin automatically.
I live in europe. It would be very expensive to send my xbox to microsoft. Isn't there solution to fix it by myself?
trust me i have been going through the same problem as of lately and done hours upon hours of research on this topic if you check all of those things i mentioned below and it does not help you idk what to tell you (also try turning on your game mode in your tv options menu or turning off all other settings that may cause lag such as resizing picture and such)
