Hitachi 50V500 50 in. HD-Ready LCD Television Logo
How do you get a fullscreen on hitachi lcd tv?
We only have a wide screen we do not have a full scren, can we change that?
4 Related Answers
Anonymous
  • 149 Answers
  • Posted on Mar 29, 2008
SOURCE: Wide Screen vs Full Screen
look for screen format in video mode menu or if you have original remote you have that option in your remote
Anonymous
  • 5138 Answers
  • Posted on Feb 19, 2009
SOURCE: Hitachi 42" Wide Screen TV - color seperation, double images
Replace Both of your convergence ICs they are big black ICs and ck resistors RK4246,50,54,58,62 i have the values if you need them they are 1.5ohms up to 3.9ohms.ICs will have STK392-110s if this is the number on yours upgrade to 180s
Anonymous
  • 33 Answers
  • Posted on Apr 29, 2009
SOURCE: need to move a 57 inch hitachi rear screen proj TV
No, do not attempt this as you will damage the unit if you try to take it apart and reassemble it. They are not built for dis-assembly and re-assembly. They are easily damaged. Rather, rent a large industrial hand truck and use several straps to secure it to the hand truck and about three men to help you. It is about the only way to do it.
Be careful... there is a fragile mirror inside which can be broken if bumped abruptly.
Anonymous
  • 27 Answers
  • Posted on Jun 14, 2010
SOURCE: Hitachi C50-FD2000 Screen Distorted
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
1helpful
How do I make the screen on my sanyo tv full- It has a black bar top and bottom
Your TV remote control (not the cable box remote control) would have to have a button that would allow the changing of the TV screen sizes. My Sony TV control has a button called, ' wide', and when pressed will change my screen to either, full, wide zoom, and zoom. Only zoom gets rid of the black bars on my TV. If no button, than the screen size will be determined by the broadcaster.
Cannot change the picture back to full screen. remote control want return the picture to full screen with the
Hi, Turn your TV on, select the menu and see if there is something in picture settings (wide screen or full screen) Try to connect a DVD player using HDMI cable. See if there is any difference.
Some DVD players will also have screen sizing. If nothing helps contact TV repair. Good luck
2answers
40 in LCD Proscan TV, Horizontal pic too wide, adj?
just look at the owners manual of how to adjust the picture
Random 3'' vertical red line on 42'' Hitachi Plasma TV
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.////
My blue ray movies are showing wide screen instead of full screen
You have to the System Settings -> Video Settings and change the view mode from "Widescreen" to "Fullscreen"
I can not get "fullscreen" on tv via laptop--when i click the "fullscreen " icon in laptop toolbar it freezes tv rather than going full screen
You should search for how to get "overscan" on your laptop model. ... I have a mac mini plugged into an LCD tv and in order to get it fullscreen i had to enable overscan.
Unable to view fullscreen in hdtv
That is the way HDTV is viewed on many screens as a wide fromat. So you will get top and bottom non-viewable areas. It is the width that gives the full imagery for that format. To have the screen filled you would get a standard 4:3 format like standard TV. HD is a 16:9 format so it is much wider.
1helpful
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
