Drills Logo
Will Posted on Feb 25, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have just purchased a Makita 8391DWPETK 18V Cordless Combi Drill - how do i actually put a drill bit in? Do I need to take off the plastic ring?
Repair Ahjoshe
Level 3:
  • Makita Master 885 Answers
  • Posted on Feb 27, 2012
Repair Ahjoshe
Makita Master
Level 3:
Answers
885
Questions
0
Helped
642954
Points
2112
The large black part of the chuck should turn left and right to extend (close) and retract (open) the three chuck teeth that hold the bit in place. Turn the chuck to open it far enough to get your bit fully in the chuck then turn it closed to hold the bit in. When the teeth make contact turn the chuck a bit further to get it tight enough that the bit won't slip. When you get used to it, sometimes it's easier to hold the chuck lightly and turn it by lightly squeezing the trigger to turn the chuck with the drill motor.
5 Related Answers
Anonymous
  • Posted on Feb 22, 2008
SOURCE: makita 6222D hole drill bit is stuck
When this happened to me I held the shaft of the drill bit tightly with my hand and reversed the direction of drive for an instant. It released at that point. It still does that occassionally though.
A
Anonymous
  • Posted on May 23, 2008
SOURCE: makita dc1804f charger will not charge new i-mh 1834 18v battery
I think your tryiong to charge NIMH batteries oon a charger designed for Lithium Ion batteries. With all the new style batteries such as NICAD, NIMH and LI-ION, charging becomes difficult. Most chargers pre NIMH and LI-ion, were designed for NICAD's. The best advise, match your batteries with the correct charger
Anonymous
  • 313 Answers
  • Posted on Jun 09, 2008
SOURCE: makita 1420 - 14.4v 1.3Ah cordless drill
try toolpartsdirect.com & go to makita & type in model #
Barry Benjamin
  • 9 Answers
  • Posted on Dec 04, 2008
SOURCE: drill bit is stuck inside my makita drill chuck
Try using the low torque setting on the drill when reversing and something to assist you getting a better grip to hold the chuck from spinning when reversing. This may help.
Good Luck
Anonymous
  • 2176 Answers
  • Posted on May 25, 2009
SOURCE: lost 18V AC adaptor- can I use one made for laptop with 18V output?
I don't know if I would try this or not. there could be a difference in the amps and usually a charger is designed to shut off or go to trickle when the battery is fully charged.
2answers
Why will a makita Li-ion 1.3ah battery not fit in other makita tools?
Some of the Makita 18v LXT tools require the BL1830 3.0AH battery and are designed that the 1.5AH battery will not fit.
Replace chuck on Makita cordless drill
The BTD 140 only has a sleve, spring, washer, clip and 2 balls. If you need to replace the bit holder then it is part of the shaft (324432-0) that comes from inside the gearbox.Cover unscrews from the body.
4helpful
Replace brushes on makita bhp452 drill
Here's a link on how to remove brushes.http://www.youtube.com/watch?v=x-drC2HEzRo
How to change bits
The drill uses a cordless chuck (part bits go into) you will need to hold the outside ring of the chuck and spin it to loosen the jaws on the bit. Then spin the chuck the opposite way to tighten
The screw point got stuck inside of the makita
Low quality steel drill bits get stuck in the Makita because the hammer impact squashes the metal, forming a ridge that gets snagged on the anvil's steel ball bearing. Use only impact drill bits.
1helpful
My makita impact driver has lost power. it seems to be using the hammer much more and seems to be slipping. both the hammer and the andvil don't appear worn. the bushes are fine. what could be the problem?
This is more then likely caused by the plastic gears inside the drill wearing down. Makita may replace/repair under warranty depending on when you purchased the drill.
We were using a makita cordless power drill. Somehow the clutch got stuck and it won't spin or open where you put the drill bit in. The motor seems to be spinning, think the problem is just in the...
keyless chuck. grab the ring immediately behind the chuck and the tampered chuck piece with a padded channel lock plier. turn the chuck part clockwise to release.
Jammed short shank drill bit in ring grabber drill driver
Mix a little JB weld stick anything to head of stuck bit. let harden and pull the sucker out.
Makita 18volt 6347 cordless drill
then you need transmision assy. item 14 in breakdown
see toolpartsdirect.com for further info on your drill
Top Makita Drills Experts
Sean Wright
Sean Wright
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Makita Drill Expert? Answer questions, earn points and help others
