Edirol UA-4FX External Sound System Logo
Anonymous Posted on Aug 10, 2006
Problems with the internal efxs.
I just opened my UA4FX and pluged it. The audio tranfer between the module and the computer is fine but I can't get the onboard efxs to work. None of the lights on the module lights up. Is it broken?
  • Anonymous Aug 12, 2006
    The leds of the audio level lights up and the ubs led also lights up.
A
Anonymous
Try this... 1.unplug your UA-4FX and switch your "sampling rate" to 44.1. plug it back into your USB port. it should turn on. 2.if thats no the case, turn off your computer and unplug the device. Turn on your computer and plug it back in when your system if finished starting up. hope i helped! good luck!
Anonymous
Level 2:
New Friend:
  • Expert 163 Answers
  • Posted on Aug 11, 2006
Anonymous
Expert
Level 2:
New Friend:
Answers
163
Questions
0
Helped
121796
Points
370
This is a usb bus powered, and maybe you got problem with the usb port, this happen many times the port can supply the correct voltage to the unit, do you have acces to other compu? try in it, if not then you are rigth, the ua-4fx is broke...good luck
How do i tranfer external calls on the Uniden 1735-2. (I know how to internally transfer, just wish to tranfer to another externel number).
I don't think you can transfer to external. You can make a 3 way call, but then you would have to stay on the line to keep that line open.
How to fix forgotten power on password problems?
You can try to open your notebook, and take the internal battery off, to reset your BIOS. You must do that without charger or battery pluged in to the computer.
1helpful
My computer breaks down (blue screen), when I try to run my ua4fx with its own drivers I think it has something to do with my motherboard (AsRocks) and the interface. maybe a compabillity problem. I...
Try this solution. -Restart then Before Windows will appear, Click F8 then Safe Mode. then restart it again and your PC will be revive it back to normal If Problem Not Solve, Reformat it . then make a Back files for drivers and programs :D
i Hope, My Solution will help you .
Scosche EFX work with MOS-FET Amplifiers
CAN YOU E-MAIL ME THE MANUALS FOR THE VOLFENHAG ZX 7150 AND THE ZX 7170 MY E-MAIL IS [email protected] thank you Thomas Anderson
Audio buzzing
check where your pluging the red sounds like your pluging a video signal into an audio jack or your red cable ha an open ground
I have the iPod software loaded on my computer. It works fine. My question is if I delete something from the "library", why is it not removed from my iPod? How do I get it off my iPod?
ok this is easy. :)
when you plug your ipod into your computer it will ask you if you want to "tranfer purchases" say no.
and if that still doesnt work, try not just deleteing it, but un-checking the item, pluging in the ipod, then deleting it.
hope i helped :)
I have a behringer djx 700 and i got an efx 1000, and would really help me if you no how the best way to connect it to the mixer my dj setup is 2x pioneer cdj 1000 mk3 1x behringer djx700 1x pioneer...
ok has the mixer got a send and return phono sockets if it has not the efx unit will have to be wired between your mixer and amp.this is not the best way . what does the efx / effects unit do .
UA-4FX Very static-like feedback / interference
its electromagnetic interference from power source of laptop. you can get an audio connection wire that reduces this
Packard bell CD rom
Cheak cd rom data cable pluge in maight be cable is unpluged and verify the port connection also
Speaker Problem
Nothing is wrong. Most computers automatically turn off the internal seakers after the external seakers are connected. Go to cntrol pannel and see what you can do under audio options or some such equivelent. Check back with more problems,
hope this helped/helps.
Top Edirol Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
