Had a problem with the battery and I think this has affected the alarm, now the. We jump the battery and turn the engine over the car starts but as soon as it does the alarm goes off so the engine stops, we need to disconnect the alarm to get the car running
If you look under the dash to the left of the brake pedal... you should see your fuse panel... above the there should be a black or gray box w/ two sets of wires coming from it ... both sets of wires have inline fuses... try pulling out either of those fuses one at a time , ie. pull one fuse try to start the car if the alarm still goes off replace that fuse and try the other one... this should disable the alarm on your car.
SOURCE: is there an installable battery disconnect switch for jag s type
u can install a disconnect but when u disconnect the power it clears all settings in vehicle such as radio will have to enter code so anti-theft lock out doesnt occur or have to reset from loc to normal -memory seats -emissions reset which means that problems for inspection if vehicle doesnt cycle thru before one is done -have battery and alternator tested most auto stores do this for free -- if problem only happens during rain check connections around battery/alternator/and fuses for loose or connections that are getting wet
