Is the DYNAMIKE turned all the way to the right? Check the mic wires, pin 2 on the mic plug is the audio wire, If you are using a stock mic the audio wire is yellow. If you are using an astatic mic, the audio wire is white. Is the PA/CB switch in the CB position? Does the radio have weather capability? if so make sure the weather/cb switch is in the cb position and the weather channel selector is set to off.
Are we talking about a DLP TV. If it is, your best bet is to remove the back cover and use a leaf blower to clean.. Heat is a number one problem with these. The dust I'm talking about has accumulated on the cooling fins. This may work temporarily. But the repair is to costly....even if it is repaired, you may get another 45 days if that. Save money and buy a new TV. Thanks for asking, Matt of Martins TV.
id say even though you think your air induction valves are closed they in fact are not , if all the jets get air in them look for leaks in pump or piping this might be more evedent if run slow or off as pump cant suck air in hole if its off , if not air induction valves can be rebuilt by obtaining the parts from mfg
Check the theremostat probe to see if it may be too close to the evaporator fins behind filter if touching fins it will feel evaporator being cold before room air and send model number too, Sea Breeze
Guess you checked the coil?If so check that stater?thing at the base of front cyclinder,has fins on it.It's part of electrical system fires the coil and runs other stuff voltage regulater things like that.Don't forget your electronic ign.Sending unit may be shot.[condenser].
The locking front hubs are vacuum actuated. You need to inspect the vacuum supply to the hubs. I would provided a schematic of the system had you provide the vehicle year
Have you checked the CPU fan? If not, open the case and inspect the fan and the cooling fins. Clean as needed to insure good air flow. You may need to remove the fan from the cooling fins. Also check the vents in the case to make sure they are not plugged with lint. Vacuuming the case openings would also be a good idea. When everything is back in place, turn on the computer and watch the fan to make sure that it is turning freely. close the case and let the computer run for a few minutes and the recheck the temperature.
Good luck, and please let me know how it works out for you!
You should not recheck BP until at least 15 minutes after the first check because it will always get higher on reading even with a manual BP machine. As a retired nurse I have both an automatic HoMedics which I I lost the manual for and a old type arm BP cuff. My automatic is pretty close to the other cuff in readings so I know it is close. Try waiting for a while before you recheck and not talk or move around when you take it.
Coffy, if you are talking about the hot surface indicator lights, they are controlled by the limiter on the burner itself. When the burner heats up the limiter closes and sends power to the light (hot surface). When the burner cools the limiter is supposed to open cutting power to the hot surface indicator light. They may be stuck closed. If you are talking about the lights on the back panel, that is controlled by the infinate switch itself. Catriver
