To help you guide to delete the application or the games icon that are appearing on your tablet desktop screen, please follow the steps mentioned below:
- You can hold your finger on an app shortcut/long press an app icon on the home screen of your tablet.
- All icons will get smaller, a border will appear around the icon you pressed and you can see a trash icon displaying at the bottom right corner.
- Just drag and drop the app shortcut from desktop to the trash can or Recycle bin.
If your tablet is wit Android system you can do a factory reset from the Android System Recovery menu. To go into the recovery menu, press and hold the Power On button and some other key (Volume Up, Volume Down, Home ). The combination is different for the different models.
When you are in the Android system recovery menu, use The Volume Up/Down keys for navigation and the Power button for confirmation.
Choose "wipe data / factory reset"
For Android tablets you can do this wit factory reset from the Android System Recovery Menu. This will erase all your data.
To go into the Recovery menu, press and hold the Power On button and some other key (Volume Up, Volume Down, Home ). The combination is different for the different models.
Steve, Below are steps to get the mac address on your Dell Streak. From the home screen:
Tap the Menu key
Tap 'Settings'
Scroll down and tap 'About Device'
Tap 'Status'
The MAC is listed under 'Wi-Fi MAC Address' How to find the IP address on your Streak: From the home screen:
Tap the Menu key
Tap 'Settings'
Tap 'Wireless Controls'
Tap 'Wi-Fi Settings'
At the bottom, under 'Wi-Fi Networks', tap the connection you are connected
to and the IP address will be displayed on the next screen Thank You, Dell-Jesse L Dell Social Media and Communities
it seems to have a reset button internally that might be worth a try. otherwise a full hard reset may be worth trying but that erases all data so backit up 1st. how to hard reset dell streak 7 hope that helps
ANDROID Tablet Freezes at Android startup screen For Superpad VI - 10.1" Android Version 4.03, this worked for me!
1. Press & hold START button 2. When "VIMICRO" appears, Then Press & Hold the MENU button 3. The Android System Recovery <3e> Menu should appear 4. Scroll down using the Volume Key to "wipe data/factory reset" 5. Press HOME Button 6. Scroll down to "Yes - delete all user data" 7. Press the HOME Button At this point the system will do a recovery and hard start, and will be on "reboot system now 8.Press the HOME Button Your system should reboot normally, but you will need to enter all new data, as it has been wiped clean.
There is no manual for Android Operating System (OS) as such because different vendors (like Dell, Samsung, etc) can customize the OS. So no manual will work on all devices. You can however look at your product manual. Btw, for most of the common tasks you can do a simple search on internet and you will get the answer. Otherwise, just post the question here on fixya.
As mariolands said, there is no trash bin because Apple wants to make the device as simple as possible for users to use. Actually, if you think about it, a trash/recycle bin is not even necessary as the user does not need to worry about things like that.
If you were wondering how to remove apps, then you have to hold any app icon on the home screen for several seconds until they start wiggling. As they begin to wiggle, you should see a cross in the top corner of each app. To delete an app, just tap on the "x" and it should be deleted.
As for the mail, once you're in the mail app, just swipe right on the message you want to delete and an option to delete will appear on the right. Alternatively, you can tap Edit at the top right and select the message(s) you want to delete.
Hope this helps,
-virjog
